03-01-2021, 10:45 AM | #1 |
Which fuel fittings?
The connection from the copper fuel line to the newly installed gas tank in my '38 Ford standard has a small drip no matter how much I try to tighten it. I'm thinking the old fitting is no longer good?
I'm guessing it's the 2 piece with nut and ferrule, but want to make sure I order the correct one...Which of these two fittings is correct, and what are the different uses between the two? https://cwmoss.com/products/fuel-lin...-piece-1932-48 https://cwmoss.com/products/fuel-lin...-piece-1928-29 |
03-01-2021, 10:58 AM | #2 | |
Re: Which fuel fittings?
03-01-2021, 11:43 AM | #3 | |
Either fitting will leak if over tightened, keep that in mind.
Sometimes, ingenuity gets in the way of sense and sanity. |
03-01-2021, 12:04 PM | #4 |
Fair point, but I'd like to have the fitting in hand before starting the job of draining the tank and and removing the old connection. I guess I can just order them both! :-)
03-01-2021, 12:06 PM | #5 | |
03-01-2021, 12:14 PM | #6 |
use a new olive. |
03-01-2021, 12:14 PM | #7 |
I prefer the two piece design. I have successfully removed the ferrule from a one piece and used with an ferrule from a one piece. Often there is enough slack in the length of a pipe that it can be shortened the amount needed to use it with a new ferrule.
Mart. |
03-01-2021, 12:47 PM | #8 |
Don't over tighten. At the point your thinking of, cut the line or get a new one. Makes do difference if one or two piece then....
03-01-2021, 03:18 PM | #9 |
Change to STEEL fuel line like original and the problems will go away.
In some places, copper fuel and brake lines are illegal and insurance companies definitely don't like them. |
