11-08-2022, 03:59 PM | #1 |
Model A Ford 7 Tooth Steering Box Oil Capacity
I have a 7 tooth steering column. Just rebuilt it. Installed in car. Went to fill it with 600W oil and the Les Andrew’s book and anywhere else I read online says it takes 7 and 3/4 ounces. It only took 4 and 1/2 ounces and is full to the plug. Clean box, just rebuilt, no old grease or anything in there. Am I missing something here?
11-08-2022, 04:18 PM | #2 |
Re: Model A Ford 7 Tooth Steering Box Oil Capacity
Move steering back and forth if on jacks to move oil around
www.whidbeymodelaclub.com Last edited by Gary WA; 12-30-2023 at 02:37 PM. |
11-08-2022, 04:22 PM | #3 |
Yes I did that as I was filling. Front wheels off ground, turning steering wheel back and forth from stop to stop. Still only took that much. About 4 and 1/2 ounces.
11-08-2022, 04:27 PM | #4 |
600W is thick, goopy stuff. Drive it a bit and check your level frequently. You may have an internal bubble that just needs time to clear. Half full for a short period of time should not be fatal.
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
11-08-2022, 04:32 PM | #5 |
