11-08-2022, 06:04 AM | #1 |
oil pump gears
Just took my oil pump apart and noticed that the idler gear has a flat side and a beveled side, which side goes towards flat plate?
11-08-2022, 10:40 AM | #2 |
Re: oil pump gears
Do your gears look like these?
First pic is of the original gears, second pic shows the replacements. Also I added a pic of the bottom plate so you can see the contact marks.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
11-09-2022, 09:33 AM | #3 |
Re: oil pump gears
Great! thanks for the pictures, the first one looks just like mine both bevels down towards pan. Not sure if it mattered, but didn't want to screw it up, thanks again!
11-09-2022, 05:20 PM | #4 |
Re: oil pump gears
