Old 05-14-2022, 11:50 AM   #1
wga
wga's Avatar
Default 49 spindle removal
Need some help on front suspension rebuild.
According to the 49 service manual, to remove the spindle, the upper expansion plug is removed. Then drive the spindle out, which removes
the lower expansion plug.
How do you remove the upper expansion plug? My plan was to make a hole with a punch and enlarge it, get a small pry bar into it, and remove the plug. So far that approach is not working.
Suggestions?
Thanks
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 05-14-2022, 12:41 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 49 spindle removal
Look here:
https://www.jalopyjournal.com/forum/...issue.1076031/
Hopefully, your service manual has pictorials with instructions.
TAKE PHOTOS OF EACH STEP.
Your approach will work. Remove the expansion plug by first loosening it with a a sharp pointed prick punch with the point of the punch facing inward towards the center of the plug. Make a series of "prick punch indentations" around the perimiter of the plug. This loosens the fit of the plug by forcing the metal plug inward away from its edges. Then carefully pry the plug up and out.
Then remove the spindle lock pin that holds the king pin (spindle pin) in place. Then drive out the spindle pin through the spindle support to remove opposite expansion plug on the bottom. Then, take photos and remove spindle bearing assembly.
My 49-51 Mercury Service Manual has detailed info. if you need it.
Old 05-14-2022, 03:28 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Suggestions?
Thanks
Remove by drilling holes as required to pry off cap.
Then remove the horizontal tapered lock pin to drive out kingpin.
Until you remove the horizontal pin you are not going to be able to remove the kingpin.
Old 05-15-2022, 08:37 AM   #4
Frank Miller
Frank Miller's Avatar
Try drilling a few holes and install hex headed sheet metal screws to push it up.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 05-15-2022, 09:36 AM   #5
wga
wga's Avatar
The Ford service manual has no pictures, diagrams only. Always take pics prior and during the process. The horizontal pin was removed.
Will drill a few holes and also use the hex head sheet metal screws.
Thanks for all the suggestions, will advise as progress continues.
Old 05-15-2022, 11:10 AM   #6
19Fordy
19Fordy's Avatar
wga: The deep recess at the top of your spindle support in your photo suggest that the expansion plug has fallen out or already been removed and never replaced. That expansion plug is very soft metal and easily deformed for removal. I suspect you are looking at the top of your hardened spindle pin (king pin).
Notice the "U" groove for a punch. Could also be hammer marks. Here's some info. from the 49-51 Mercury Repair Manual that may help. The design of the ford and merc suspension is similiar except the Ford components are not interchangeable with the Mercury as the Ford are smaller. More photos follow.
Old 05-15-2022, 12:02 PM   #7
19Fordy
19Fordy's Avatar
More spindle removal photos. NOTICE spindle support does not have to be removed to replace spindle. Hope this helps.
Old 05-15-2022, 01:34 PM   #8
wga
wga's Avatar
19Fordy - wow, many thanks. My Ford manual has the descriptions, though most of the photos were not included.
I had the same thought yesterday afternoon that the expansion cover was missing. My impression is that this suspension was never overhauled since new.
Heading out to the shop after typing this message - stay tuned.
Very much appreciate your assistance.
Old 05-15-2022, 08:29 PM   #9
wga
wga's Avatar
Success this afternoon, friend dropped by who suggested drilling more holes around the circumference might help. Five minutes later.....
Spindle is stubborn, letting it soak with penetrating oil over night. If this does
work, will remove as an assembly.
Onward....
many thanks.
Old 05-16-2022, 09:44 AM   #10
19Fordy
19Fordy's Avatar
wga: That's good news indeed. Glad you got it removed.
Old 05-17-2022, 09:33 AM   #11
rotorwrench
rotorwrench's Avatar
Ford used some type of a rotating burnishing tool to roll the edge of the boss over a bit. This helped keep the plugs in place but it required a counter bore tool to remove the lip if a person wants a new plug to go back in. Some heavy handed mechanics get carried away with staking the edge of the bore around the plug as well after new king pin kits are installed. It's always something with these old cars.
