03-29-2018, 09:29 PM | #1 |
Hand Throttle
I need to remove the hand throttle "Bell Crank" (see picture) because the tip in broken off. Does the pivot pin press into the bracket or is it pinned. Thanks
03-30-2018, 08:44 AM | #2 |
Re: Hand Throttle
Not sure but you could build up weld, weld a small extension on it, or spend $10 or less at a swap meet for a good bracket.
03-30-2018, 09:16 AM | #3 |
Re: Hand Throttle
I would think it's pressed, what does the other end look like?
I've had mine off but never looked that item over in real detail.
03-30-2018, 10:31 AM | #4 |
Re: Hand Throttle
03-30-2018, 11:49 AM | #5 |
Re: Hand Throttle
Yes it has a hole on the other side.
Another shot of broken part. I have another throttle brake that I can rob the part off of. Just need to know if it is pressed in or is there a pin that I don't see. I tried tapping it out but see no movement. Or a may just weld it... |
03-30-2018, 12:40 PM | #6 |
Re: Hand Throttle
Paul in CT |
03-30-2018, 01:44 PM | #7 |
Re: Hand Throttle
03-30-2018, 02:58 PM | #8 |
Re: Hand Throttle
A small bit of weld and a grinder and it is done!
03-31-2018, 01:31 AM | #9 |
Re: Hand Throttle
You should be able to tap the pin up and out, but I'd leave it in place and weld up what's missing.
If you have the good spare part, then tap it out. |
03-31-2018, 08:22 AM | #10 |
Re: Hand Throttle
A small gear puller may work to push that pin out. Don't forget the penetrating oil.
03-31-2018, 09:16 AM | #11 |
Re: Hand Throttle
It is pressed in.
I pressed mine out to repair that assembly to eliminate wear between the pin and arm. Shouldn't be any "wobble". I have a Dake Arbor Press and it pressed right out. |
03-31-2018, 10:52 AM | #12 |
Re: Hand Throttle
Awesome, that is exactly what I needed to know. I have a press but I didn't want to start pushing' until I knew for sure.
