01-15-2024, 10:25 AM | #1 |
49-53 cam gear
Ordered a new cam gear 49-53 and the teeth are cut opposite of my original
gear anyone experience this? |
01-15-2024, 11:21 AM | #2 |
Re: 49-53 cam gear
The direction of thrust of the camshaft was changed on the 49-53 engines from the direction of the earlier model flatheads. So, either they sent you an early camshaft gear or your engine was built incorrectly with an early cam gear at some time.
01-15-2024, 11:33 AM | #3 |
Re: 49-53 cam gear
Which cam gear does the crank gear match?.......Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
01-15-2024, 12:36 PM | #4 |
Re: 49-53 cam gear
Someone had early gears on a late block so I am putting the latter gears in
Thanks |
01-15-2024, 12:48 PM | #5 |
Re: 49-53 cam gear
Here's some really good info.
https://www.fordbarn.com/forum/printthread.php?t=159637 |
01-15-2024, 02:05 PM | #6 |
Re: 49-53 cam gear
01-15-2024, 07:13 PM | #7 |
Re: 49-53 cam gear
Mine has the late dist.
01-15-2024, 07:37 PM | #8 |
Re: 49-53 cam gear
I just disassembled a 49 8BA and it has the early gears in it. Is there a real problem with that? I know you can’t use the later gears on the early engines with the front mounted distributor.
01-16-2024, 06:05 PM | #9 |
Re: 49-53 cam gear
Either gear set will work. Get a good set of either style of gears and you will be fine. My personal preference is an aluminum camshaft gear instead of fiber.
My understanding is Ronnieroadster has done testing and found that the helical gears driving the oil pump thrust the cam in the same direction regardless of the timing gears. |
01-16-2024, 06:14 PM | #10 |
Re: 49-53 cam gear
"My understanding is Ronnieroadster has done testing and found that the helical gears driving the oil pump thrust the cam in the same direction regardless of the timing gears."
That is very interesting. I hope Ronnieroadster will provide more info. on his findings. |
01-16-2024, 06:29 PM | #11 |
Re: 49-53 cam gear
And then there are straight cut gears for those that want to go fast.
01-16-2024, 07:07 PM | #12 | |
Re: 49-53 cam gear
01-16-2024, 07:14 PM | #13 |
Re: 49-53 cam gear
THANK YOU 38 coupe for posting the link to Ronnie's research.
Very enlightening. Read every word. |
