09-06-2020, 10:45 AM | #1 |
1947 back up light switch bracket
I have acquired a back up light switch for my '47. It is a plunger type that mounts with a bracket, so I am told, on the steering column. I am looking for the bracket. A couple photos might help if someone has one in place that could tell me how to fabricate it. I have never seen one so do not know if it is a cast piece of flat stock which could be cut and shaped to fit.
Any help is appreciated. David [email protected] 207-590-0180 |
09-06-2020, 05:24 PM | #2 |
Re: 1947 back up light switch bracket
David, I have the Ford back-up-light on my '47....think it was an original Ford accessory. The switch is a "push/pull" that's mounted on the dash (left of steering column) between the headlight switch and the throttle pull. Guessing that the hole for it was drilled by the dealer for installation. It looks like it belongs there, right next to the light switch. The dash light dimmer rheostat is underneath the dash, over by and just to the right of the E brake handle.
Hope this helps. |
09-06-2020, 06:30 PM | #3 |
Here is what you need
https://cgfordparts.com/ufolder/ford...er=51A-15517-A It mounts on the column on the inner bolt that holds the shift arm support between the steering box and the firewall. Hope this helps?
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
09-06-2020, 06:54 PM | #4 |
Merc42 thank you. That is a simple bracket and hard to believe someone reproduces it. I will check out support that holds the shift arm to see if I can imaging how it fits.
09-06-2020, 08:25 PM | #5 |
I can take a photo of mine when I get home from work if you need that?
09-06-2020, 09:45 PM | #6 |
09-07-2020, 12:07 AM | #7 |
Here are the pic's as promised
09-07-2020, 09:24 AM | #8 |
David and meric42, I sure learned something about the Ford backup light from these posts!! If I understand this correctly, the light goes on when the shift lever goes into reverse and off when shifted out of reverse?
Makes my toggle switch on the dash seem kind of "primitive"!! (But, it was there when I bought the car.) David, thank you for posting your question and meric42 for posting those two great pictures and the source of the bracket at C&G Ford parts!!! |
09-07-2020, 10:47 AM | #9 |
I added a repo backup light switch and bracket to my '51. It fir perfectly. When I cleaned up the backup lights themselves, I came to the opinion that were pretty big and "klunky" and I decided not to use them. So I am using it to activate my backup camera. (Once you get used to having one, they're nice to have.)
09-07-2020, 11:11 AM | #10 |
Denny, I'd say better than "nice". How about "essential"? Lots of mishaps avoided. Happy to see universal on new cars now.
Clever the way you hooked it up! |
09-07-2020, 07:48 PM | #11 |
The photos help a lot. I'll be ordering that part from C&G and hopefully the switch should install early. I'll just have to wire it in. The one if the photo is somewhat different than the one that is being shipped to me. but maybe there are variations due to different vendors.
In any case it should make the back up lights installation more correct. These lights are about 3" in diameter and I think are repros but very similar if not the same as the originals but have no Ford marking on them. The worst part of the '46-'48s are their R rear view mirror. They are only for show, as they cannot be seen by the driver. Useless. The L side isn't much better. Thanks again to all who contributed and especially toe '42Meric for the info and photos. Helps a lot. Any idea how the wiring is attached and from where? I noticed the wiring is missing on the switch. |
09-08-2020, 12:29 PM | #12 |
David, certainly agree with you, re the mirrors. Right side is decoration only....totally worthless. So, got a windwing mirror...part#A17700WW in Mac's catalog and mounted on the crank out vent glass. Put a convex stick on mirror of the same size. Can now see everything in the right blind spot. With the top up, the inside mirror is worthless, but I'm good with the left outside one for checking the left lane.
09-15-2020, 04:50 PM | #13 | |
09-18-2020, 08:34 AM | #14 | |
09-18-2020, 08:39 PM | #15 |
I mounted the camera on the rear license plate. That was the easy part. The screen is he hard part. Currently, I have it temporarily mounted on the dash board above the radio. It is not a good place, and I am currently looking for a rear view mirror with an integral screen (they are too expensive now, in my opinion). Also, routing the video cable is a problem.
09-19-2020, 04:24 AM | #16 | |
09-19-2020, 05:56 AM | #17 |
When wired as original on my 49 ford the backup lights only come on when the headlights are on. I guess they were originally meant for night use before someone figured out that they make a good signal for those outside the car of the driver's intention to back up.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
09-19-2020, 02:07 PM | #18 | |
Ian, here are two pics of mine. One light on the left side rear. Second picture shows...I hope...."Ford" inscribed on the top of the light. Light is operated by a push/pull switch on the dash. Have no way to verify now, but think this was a dealer installed option at the time of original car purchase. Backup Light 1.jpg Backup Light 2.jpg |
09-19-2020, 03:05 PM | #19 | |
09-19-2020, 06:39 PM | #20 |
I have a 49/50 backup light bracket and switch that I installed and works on my 47 car.
It just took awhile to figure out how to mount it so it works !! |
