Old 09-28-2013, 04:56 PM   #1
52merc
52merc's Avatar
Default frame#
where on a 36 frame will I find the #ss
trev,, whats life "TOUGH" whats tough ' LIFE"
52merc is offline   Reply With Quote
Old 09-28-2013, 04:59 PM   #2
4dFord/SC
4dFord/SC's Avatar
Default Re: frame#
The most accessible one is on top of the left (driver) frame rail by the front cross-member. They can be challenging to to raise from under years of grease, dirt, and rust.
4dFord/SC is offline   Reply With Quote
Old 09-28-2013, 06:39 PM   #3
TJ
TJ's Avatar
Default Re: frame#
On a 36 it's on top of the left frame rail and near the steering box mount. This is the most common area for 35-37. You should check the entire top of the left frame rail from the firewall to the front crossmember as they were stamped while the car was moving on the assembly line.
Old 09-28-2013, 07:07 PM   #4
swoopNZ
MEMBER EMERITUS
Default Re: frame#
On a RHD chassis it should stamped on the RH side of the chassis rail near the front cross member.
swoopNZ is offline   Reply With Quote
Old 09-28-2013, 07:45 PM   #5
52merc
52merc's Avatar
Default Re: frame#
thanks been looking but cannot find oh its for lhd car
Old 09-28-2013, 09:19 PM   #6
ford3
Default Re: frame#
Trev, i have found those numbes from the frame horn on front of frame , and any place on frame all the way to cab and even under the cab, some were stamped very lite, rust remover and wire brush time,
ford3 is offline   Reply With Quote
Old 09-29-2013, 12:17 AM   #7
52merc
52merc's Avatar
Default Re: frame#
how are you mate I have not heard from you for a long time trev
