Old 01-18-2021, 08:29 PM   #1
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default How To Remove Cosmoline
I have a French block that will be getting built soon but how do I remove the cosmoline?
What I know is that it’s a wax and hot water will melt most of it and then WD40 or something like it will remove the rest.
Have any of you ever Erne it and, if so, how did you do it?
Thanks for any help you can give .....
TomT/Williamsburg is offline   Reply With Quote
Old 01-18-2021, 08:41 PM   #2
Brian
Brian's Avatar
Default Re: How To Remove Cosmoline
there's probably an easy way, but I've always used a solvent and elbow grease!
Old 01-18-2021, 09:25 PM   #3
DavidG
DavidG's Avatar
It melts rapidly in the presence of lacquer thinner.
Old 01-18-2021, 10:00 PM   #4
TomT/Williamsburg
Thank you - lacquer thinner it is then. And elbow grease will come in handy I am sure!
Old 01-18-2021, 10:05 PM   #5
cas3
gasoline, and use a brass brush
Old 01-19-2021, 12:34 AM   #6
WABOOM
WABOOM's Avatar
We used a heat gun on surplus rifles. Followed by ATF, then mineral spirits. Worked great.
WABOOM is offline   Reply With Quote
Old 01-19-2021, 08:51 AM   #7
Tim Ayers
https://www.amazon.com/CRC-Heavy-Deg.../dp/B000R833ZE
I've used this CRC product with good results.
Old 01-19-2021, 11:52 AM   #8
GB SISSON
GB SISSON's Avatar
Followed by the ATF?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 01-19-2021, 01:29 PM   #9
gajeepguy
A million GI's have used gasoline, but do it outdoors and do it safely.
gajeepguy is offline   Reply With Quote
Old 01-19-2021, 01:34 PM   #10
Krylon32
I to have a French block and since I can't get any interest in buying it I may have to build it. Can't you just have the machine shop hot tank it to remove the cosmoline?
Krylon32 is offline   Reply With Quote
Old 01-19-2021, 01:37 PM   #11
Scotty's 52 F3
Scotty's 52 F3's Avatar
Hot tank or parts washer is what we used at the Cat dealership. For small parts, the solvent tank. The pressure washer outside was often used to knock the majority off first.
Scotty's 52 F3 is offline   Reply With Quote
Old 01-19-2021, 03:22 PM   #12
Hal Beatty
Hal Beatty's Avatar
For aircraft brake rotors in cosmoline we always used Avgas; sometimes it had to soak for a week or so on parts that had been coated for 70+ years.
Hal Beatty is offline   Reply With Quote
Old 01-19-2021, 03:44 PM   #13
rotorwrench
rotorwrench's Avatar
In the military we used PD-680 which could have been perchloroethylene or trichloroethylene depending on the suppliers at the time. We would drop the component in the vat and let it set there a while (usually overnight) before brushing the goo off.
The stuff will melt if you have some form of hot tank when the crap is too hardened to get it all off in the solvent only method. Just don't heat any chlorinated solvents up too much or the gas from it will kill you. Hot water or normal water soluble parts cleaning solutions would be better under extreme heat but you have to get it all off of there after cleaning.
Old 01-19-2021, 03:54 PM   #14
Mart
Mart's Avatar
For the pistons I did recently I used white spirit (mineral spirit) in an ultrasonic cleaner. It worked really well. I think the heat helped a lot. If using cold then a different solvent may be better. I showed the pistons being cleaned in a recent video. While this might not be any help for a whole block, the main caps can be done like this.
Mart.
Old 01-20-2021, 08:08 AM   #15
corvette8n
corvette8n's Avatar
Can’t see why hot tanking wouldn’t work, I cleaned a surplus rifle stock with boiling hot water once.
Old 01-20-2021, 10:48 AM   #16
Seth Swoboda
Seth Swoboda's Avatar
I bought a nos crank shaft covered in cosmoline. I had my machine shop bake it to remove the cosmoline.
Old 01-20-2021, 10:59 AM   #17
McMimmcs
McMimmcs's Avatar
My mechanic has great luck with a heat gun !
Old 01-20-2021, 11:25 AM   #18
WABOOM
WABOOM's Avatar
Lol... not THE a.t.f.
haha
Old 01-20-2021, 11:56 AM   #19
tubman
tubman's Avatar
After seeing all of this, I guess I was lucky that nobody was able to deliver on the "Harley 45's packed in Cosmoline" they talked about when I was in high school.
Old 01-20-2021, 12:01 PM   #20
GB SISSON
GB SISSON's Avatar
haha
Somebody got it! There was a line from some movie... "I heard a knock at my door and a voice from the other side said 'Alcohol, Tobacco and Firearms'. I thought it was a delivery".
