Old 06-22-2010, 08:46 PM   #1
firerod
Default Exhaust
Just had a 1 3/4" straight pipe built for my car. It is too loud. Anyone have ideas for a louder than stock but quieter than nothing exhaust?
firerod is offline   Reply With Quote
Old 06-22-2010, 09:29 PM   #2
firefirefire90
firefirefire90's Avatar
Default Re: Exhaust
have a resonator welded in at some place on the exhaust. It will be louder than stock, but not ridiculous.
the token youngin'
firefirefire90 is offline   Reply With Quote
Old 06-23-2010, 08:38 AM   #3
john in illinois
john in illinois's Avatar
Default Re: Exhaust
Smithy's muffler sold by Reds Headers and Jeggs are supposed to help performance and sound pretty mellow.
john in illinois is offline   Reply With Quote
Old 06-23-2010, 08:48 AM   #4
Tinker
Tinker's Avatar
Default Re: Exhaust
You can build a baffle or use a harley baffle. Although I think harley baffles are 2". Cut's it down to about 1/2 the noise. Both are not stock ford stuff though
I'll add, snyders has a stock looking performance muffler. Don't have any idea of the sound it produces but it's labeled louder then stock.
Good luck
Old 06-23-2010, 09:38 AM   #5
Model A Speedster
Default Re: Exhaust
I've got a straight pipe - no baffles - on my speedster and while it sounds awesome when you are starting out, the noise seems to die down at road speed. Maybe I'm going faster than the sound's ability to keep up, but I doubt it... That's probably not the answer you were looking for, but it's my two cents worth.
Any car can drip oil, but for a real puddle, it takes a Model A.
Model A Speedster is offline   Reply With Quote
Old 06-23-2010, 09:53 AM   #6
Earle
Earle's Avatar
Default Re: Exhaust
That's the first time I've heard of a Model A going faster than the speed of sound!
What head compression and rear-end ratio you got on that baby!?...
Earle is offline   Reply With Quote
Old 06-23-2010, 10:05 AM   #7
SUHRsc
SUHRsc's Avatar
Default Re: Exhaust
I have a hopped up B motor, high compression head, Cam, dual 48 carbs, etc... the whole she-bang... header into a long Smithy muffler...
its not very loud and annoying, but you can tell its not stock... but still has a rumpity sound to it....
this isnt a great example... but heres a video where you can hear it driving...
https://www.youtube.com/user/hotrodav...20/d7zxXJg50bc
compared to this bone stock set-up, filmed with the same camera
https://www.youtube.com/user/hotrodav8#p/u/4/M_OZmnswHfo
-WANTED-
Pre-War Speed Equipment
Davies Intake Manifold
81AS - 81SB - 99AS - 99SB cylinder heads
SUHRsc is offline   Reply With Quote
Old 06-23-2010, 10:28 AM   #8
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Exhaust
I removed the baffles from one of the Midas type mufflers that use to sell for $55.00. It is a little louder but looks original and makes a difference that you can feel in performance. Nobody notices the difference in the sound unless I tell them. I allways liked my cars to be a little louder anyway.
Old 06-24-2010, 01:56 PM   #9
firerod
Default Re: Exhaust
I used a baffle designed for Harley drag pipes. Sounds kind of funny at idle but great on the road. Thanks for all of the help.
Old 06-26-2010, 07:23 AM   #10
Model A Speedster
Default Re: Exhaust
Earle - If you're an older geezer (like me) and your hearing is not what it used to be, then a Model "A" going faster than the speed of sound is not an impossibility. FYI - we're running a stock head and rear end both on the Speedster and me!
Old 06-26-2010, 07:41 AM   #11
Richard in NC
Default Re: Exhaust
I took a stock exhaust system, drilled a 3/8" hole where the tailpipe bent starts. Use a long sharpened rod to knock several holes in the baffles. Then you weld a small patch over the access hole. Sounds good.
Richard in NC is offline   Reply With Quote
Thread Tools
Display Modes
