05-16-2019, 09:36 AM | #1 |
Oil sending unit
I replaced the sending unit in my gas tank the instructions stated 6 & 12 volt. So my question is does the same thing apply to an oil pressure unit if so what size thread an I looking for don't want to remove old one with out a replacement. Thanks for any information
05-16-2019, 10:17 AM | #2 |
Re: Oil sending unit
The sending unit should work on 6 or 12 volts. The pressure of the sender needs to be matched to the gauge.
05-16-2019, 10:22 AM | #3 |
Thanks and that should be 80 lbs if I am right?
05-16-2019, 10:58 AM | #4 |
