11-30-2018, 09:16 PM | #21 |
Re: Sanding tempered glass? Yes-No?
I find it a bit odd that your glass supplier would only do tempered glass for the side windows. '32 side glass window channels were designed for up to 1/4" thick glass as the deluxe models had laminated safety glass in all windows (the standards were only equipped with a laminated windshield and the side windows were plate glass, but laminated side glass was an extra-cost option for all of the standard models). In other words, the same glass was used in the side windows as was used in the windshield when so equipped and no tempered glass was used originally. That's why I find your glass supplier's requirement unusual, to say the least.
11-30-2018, 09:54 PM | #22 |
Yep!
Dealing with VINTAGE GLASS, LAWRENCEVILLE, GA was a learning experience. Urging others to not make the same mistake. I was naïve and didn't do my due diligence. |
11-30-2018, 10:50 PM | #23 |
All the glass in my '47 is laminated and original LOF (Libby Owens Ford). Got the marker bugs and bubbles in the edges of the laminate to prove it ! The rear window is "Herculite" tempered due to curved surface.
My local glass shop does laminated. Some shops insist on tempered because they get the higher price and less liability. |
12-04-2018, 09:32 PM | #24 |
Don't believe you can cut, sand or other wise change the shape of tempered glass. Regular auto safety glass yes.
12-04-2018, 09:33 PM | #25 |
Cut and sanded a Masonite pattern today. Curious to see what changes are required to make it fit, if at all. Just pissed that after all the delays and BS that I put up with, I have to spend more money to fix this screwup.
STAY AWAY FROM VINTAGE GLASS, LAWRENCEVILLE, GA!! Last edited by hotrodA; 12-04-2018 at 09:41 PM. |
12-04-2018, 11:04 PM | #26 | |
Charlie Stephens Last edited by Charlie Stephens; 12-04-2018 at 11:20 PM. |
12-04-2018, 11:43 PM | #27 |
You've nailed it! Makes perfect sense.
12-05-2018, 06:30 AM | #28 | |
And this allows for an emergency access into the car, But tempered glass became the norm with the introduction of curved side glass. Any safety factor was just a secondary consideration.
12-05-2018, 04:21 PM | #29 |
Too many people today are used to tempered glass where with the window half down you can reach out and use the glass as a handle to close the door. Especially on a 3 window or tudor this will likely crack safety glass.
For a driver or a street rod imho tempered is a clear choice. A true restoration needs OEM style safety plate. |
12-05-2018, 09:47 PM | #30 |
As for the original question about sanding tempered glass (or any glass), I would wear a good mask or respirator. I have various belt sanding devices in my wood shop, but I can only imagine what that dust from ground glass looks like under a microscope. Bad for lungs I think.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
