09-04-2010, 06:31 PM | #1 |
Cam Gear
I installed an aluminum cam gear in my sdn.
It makes a knocking noise like a rod bearing. Put in a bronze and it did the same thing. Put in a fiber gear,, no noise! The cam is not walking back and forth, and the crank gear is new. Could it be that the crank gear has narrow tooth causing it to slap as the gears mesh?? I need the metallic gear because I have a heavy valve spring load. Thanks JB |
09-04-2010, 06:47 PM | #2 |
Re: Cam Gear
O/S Aluminum Gear? What kind of backlash with the aluminum & bronze gear? Naturally, the metallic gears will be noisier but not always a problem. There may be an issue with the crank gear that the fiber gear is masking.
09-06-2010, 01:29 AM | #3 |
Re: Cam Gear
Jerry- Did you check the backlash as Brent asked?
You should check it at 90 degree intervals. How did you tighten the cam gear nut? Look at the wear pattern on the cam gear teeth- it should be uniform all the way across the tooth and be the same on both sides of the tooth if the gears are made correctly. If you need help, e-mail me- dmcgears AT yahoo.com. Dan |
02-08-2011, 10:08 PM | #4 | |
Re: Cam Gear
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 02-09-2011 at 10:02 PM. |
02-08-2011, 11:23 PM | #5 |
Re: Cam Gear
did you install a matched set? is the crank gear used? Your best bet is to get a matched set from Dan.
02-08-2011, 11:33 PM | #6 |
Re: Cam Gear
02-09-2011, 11:10 AM | #7 |
Re: Cam Gear
Don't bother to run any new cam gear against a used crank gear. They new crank gear will be worn. Difficult to check by sight in the engine
02-09-2011, 03:03 PM | #8 |
Re: Cam Gear
Did you grease the cam plunger and spring in the timing cover when you installed it ? It will make a racket if you don't.
02-09-2011, 04:49 PM | #9 | |
Could you have excessive center cam bearing clearance
Good luck on your search for the problem! Simple little cars should have simple to repair little problems...well we all know that's wrong! Good Day! Dave in MN Last edited by Dave in MN; 02-10-2011 at 09:41 AM. |
