02-10-2018, 08:49 PM | #1 |
Rear drums
I need a little help with the ID of my rear drums /hubs . I would like to replace the bearing inside the hub. The hub is on the insiade of the drum. I thought they were 46/48. I ordered new bearing, they measure 2.82 on the out side. However the ones I took out measure about 3.18 across. The rear end is a 1932, backing plates are 46/48. Iam sure the answer is simple, I just don't know . Help
Ken |
02-10-2018, 10:42 PM | #2 |
Re: Rear drums
B-1225 is the part number for the bigger bearings you require
02-11-2018, 01:00 AM | #3 |
Re: Rear drums
Thats the part number they were to send me . I will have to call them Monday.
Thanks |
02-11-2018, 11:34 AM | #4 |
Re: Rear drums
Sounds like they sent you 68-1225.
Bob |
02-11-2018, 11:46 AM | #5 |
Re: Rear drums
