03-06-2013, 07:53 PM | #1 |
8BA Piston Clearence, Have I seen it all yet?
Here's one for Ron & Walt & John, and other engine guru's to comment on....
(And, no, I'm sure I haven't seen it all) I was at my engine builders shop a couple days ago. This is a one-guy shop, specializes in flatheads, bangers, and other oldies, but mostly flatheads. He showed me an 8BA that a customer brought in, customer said it had a knock, and could they fix it. And, the engine is supposed to be 'rebuilt', by someone else. The engine is all spic-n-span clean, freshly painted (copper/bronze color). So, shop owner decides to pull one head, before he installs in on his engine stand to run it. Sure enough, it all looks fresh on the top of the pistons, top of valves, and gaskets look new. The Pistons are marked .040 over 3/16. However... In cylinder #2, there is a substantial visible gap between the piston and the wall. Rings are showing, and the piston can be rocked back & forth about 1/8 or so. Someone put a 3/16 plus .040 piston in a cylinder that is bored 3-3/8 !! Yes, I imagine it knocked a little. Pretty hard to believe !! |
03-06-2013, 11:27 PM | #2 |
Re: 8BA Piston Clearence, Have I seen it all yet?
Must have had a real party the nite they bored the block. When I was young I was told "The guy that checks the parts" is the real builder. Then you just put it together.
03-07-2013, 12:30 AM | #3 |
just one cylinder was bored to 3-3/8??....wonder if there is a story to that....Mike
03-07-2013, 03:18 PM | #4 |
One cylinder bored 3/8... other seven are 3/16 plus .040
Gotta wonder. Maybe Ron nailed it. (The engine builder has sinced passed on, so there is no going back to ask.) |
03-07-2013, 03:33 PM | #5 |
Wonder if it was meant to be sleeved and someone forgot the sleeve.
03-07-2013, 05:56 PM | #6 |
