Old 05-30-2020, 06:19 AM   #1
Oberfranke
Oberfranke's Avatar
Default reduce the charging current on the generator
I want to reduce the charging current on the generator. I come to this area when installed. Maybe someone can draw me where the 3rd brush is. And where the screw is. Thanks in advance.
Greetings from Germany
Gero
Oberfranke is offline   Reply With Quote
Old 05-30-2020, 07:38 AM   #2
Mike Peters
Mike Peters's Avatar
Default Re: reduce the charging current on the generator
In your second photo, the moveable third brush is shown. To decrease charging rate, simply move it upwards. No set screw, it slides on a track. I usually can adjust it with my fingers. Careful not to damage the carbon brush. A 10 amp charge is plenty. Basically, up to decrease charging rate and down to increase charging rate.
Mike Peters is offline   Reply With Quote
Old 05-30-2020, 07:48 AM   #3
DBSHELTON
I use a wooden stick while it is running. Am I doing it right?
DBSHELTON is offline   Reply With Quote
Old 05-30-2020, 08:41 AM   #4
Badpuppy
Yes, anything nonmetal is OK. Adjust higher for night driving, lower for daytime.
Badpuppy is offline   Reply With Quote
Old 05-30-2020, 08:42 AM   #5
Badpuppy
Gero, welcome to the Barn.
