Old 07-14-2016, 06:06 PM   #1
Flat32
Default Need early block valve and parts
I'm far from home and in need of a couple split valve guides, mushroom valves and springs. Used, but serviceable is fine. Want to pick up local in Bloomsburg, PA area or Chester, NJ area.
Flat32
Flat32 is offline   Reply With Quote
Old 07-14-2016, 07:52 PM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Need early block valve and parts
Hello Flat32,
I just sent you a pm and an email regarding this post, and the parts you are in need of. Maybe you could respond back to me as well as posting some additional information here on your current situation and the reason for your needs.
John
Old 07-14-2016, 08:22 PM   #3
VeryTangled
VeryTangled's Avatar
Hi Everyone, Flat32, Busy Fri, but got time on Sat-Sun. Outside of DC which means Jersey is, um, sorta close, not. JM is a very valuable and special resource, and is in the NE corner of MD, so let him, and us know what's going on and what your status is?
Start us with your block/engine vintage, and add-on list, so we can get the gear together to help get you off the east coast.
-Jeff H
Old 07-15-2016, 02:19 AM   #4
Flat32
Red face Re: Need early block valve and parts
Not urgent. Have a 1934 coupe and 1934 stock engine partially torn down. Would like to get engine together and running during a one or two day trip to NJ where car is being prepped for sale. In Bloomsburg, PA now.
Brother mucked up a valve, spring and guide taking the engine apart 20 years ago.
Don't know where the Flathead guys are hiding around these areas.
Flat32
Old 07-15-2016, 06:34 AM   #5
JWL
I have new split guides and valves if you can wait for mail delivery.
JWL
JWL is offline   Reply With Quote
Old 07-15-2016, 07:06 AM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I have good used valves--Guides and springs, If you get used guides make sure there in pairs, cain't mix up the guide pairs. Let me know where to send them. Walt
Old 07-15-2016, 09:34 AM   #7
Flat32
Walt, I sent you a PM.
Flat32
