01-14-2011, 12:14 AM | #1 |
Correct distance
Just how much space should there be from the fan to the radiator on my 59ab engine with stock fan and genertor. My radiator will probably will end up installed on top of the front cross member, making the radiator shroud higher that the cowl on the 27 t. Is this a bad thing! I see a few aroud so I am assuming I would not get laughed at. Pictures or friendy advice appreciated.
Regards |
01-14-2011, 10:10 AM | #2 |
Re: Correct distance
