10-31-2012, 03:06 PM | #1 |
Winter Storage Time!
Well, we got the ol' 49 stored in the garage for winter. What do you guys do for winter storage? Oh almost forgot! Happy Halloween! Now go scare the crap out of some kids tonight!
1949 Ford Fordor 2001 GMC Sierra SLE Joshua Landvik |
10-31-2012, 03:22 PM | #2 |
Re: Winter Storage Time!
Moth balls all over inside. Make sure the antifreez is up to par. That's it. never had a problem, last year missed one of the cars with the moth balls and got mice. PS also put out lots of poison in the storage building.
10-31-2012, 04:15 PM | #3 |
Add some StaBil fuel stabilizer to the gas tank.
Winter storage? Dang, still driving the '49 wagon out here.
Henry Ford designed the flathead without the aid of a computer. |
10-31-2012, 04:35 PM | #4 |
I like to start them up and run them a while during the winter, weather permitting.
10-31-2012, 05:02 PM | #5 |
When you use the BLUE(marine grade) sta-bil also add some MMO & run it thru the system for a bit & won't hurt to put some in the oil. Sticky valves @ startup are a pain. Disconnect the battery after it is charged up & anti-freeze check.
10-31-2012, 06:00 PM | #6 |
10-31-2012, 08:31 PM | #7 |
11-01-2012, 04:42 AM | #8 |
What's winter storage?
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
11-01-2012, 05:28 AM | #9 |
When I lived up north. I would use drier sheets, or moth balls. Roll up windows and use Stabil. I would start it up every few weeks and back out into driveway. After running for about 20-25 min. Back it goes for a few more weeks.
11-01-2012, 06:25 AM | #10 |
11-01-2012, 10:41 AM | #11 |
50/50 antifreez/coolant mix, lavender mothballs, stabil in gas, cleaned spark plugs, fresh engine oil, battery fully charged, properly inflated tires, cardboard under vehicle. I do not start my 6 cyl during the winter anymore. I used to years ago and I had problems with the front valves sticking in the spring start-up. I attributed the sticking valves from rust that occurred from running the engine, then shutting it off without the front of the engine getting hot enough so moisture would form creating the rust. Since not running my engine in the winter, I have not had sticking valves for many years.
11-01-2012, 10:54 AM | #12 |
Roll up all the windows so the racoons cain't get in. I learned that a few yr's ago. Forgot to roll the right window, a coon got in tore the rooled and pleated leatherret all up, seats door plannles, everything except the head linner. Then had a litter of little ones on the floor behind the seat. Cost me 500 bucks to get the inside done again. Walt
11-01-2012, 11:04 AM | #13 |
Work on it all winter!
11-01-2012, 11:44 AM | #14 |
When I lived up north (Long Island, NY) I drove my Flatheads year round, just tried not to take them out after a snow fall so the salt would not get on the undercarriage.
11-01-2012, 11:48 AM | #15 |
They don't use salt up here, it won't work at cold temps, and the severe cold would be really hard on the old drivelines. So I put her away about a month ago and won't be able to go back out till April. But it gives me something to do for the winter.
