02-16-2020, 07:57 PM | #1 |
Tool for removing tapered parts
I have used this tool for both modern & EV8 Fords, and works great for tie rod ends, and other taper seat parts. I just used it to get that tough to get at shock link out of the radius rod next to the backing plate. I didn't think it would work in that limited space, but it did the job in no time. I believe it was about $30. 1o years ago, and has paid for itself many times over.
02-17-2020, 11:06 AM | #2 |
Re: Tool for removing tapered parts
That is a really neat tool. They are still available.
https://www.amazon.com/GEARWRENCH-39...PT8GCQ68J247SF |
02-17-2020, 11:53 AM | #3 |
I'm really annoyed because I had one just like that, it has served me well over the years. I also used it to remove the rear shock studs.
I managed to very slightly bend the part that surrounds the joint. I straightened it in the press, and wanting it to go just a bit more I gave it another pull on the press and it snapped! I should have left it alone. I doubt anything I can buy today will be as good. Serves me right for trying to fix something that wasn't actually broke. Mart. |
02-17-2020, 11:55 AM | #4 | |
02-17-2020, 01:54 PM | #5 |
Did a little search and found that KD Tools and OTC have similar ones, look stronger than the one on amazon. I refuse to buy anything from amazon.
02-17-2020, 02:50 PM | #6 |
02-17-2020, 03:13 PM | #7 |
A picklefork is only good if you are throwing the part into the garbage after removing it...any rubber seals and often part itself gets damaged using it...
I have a few different styles pullers and the best is made from Facom and has adjustable gap. |
02-17-2020, 03:32 PM | #8 |
Right, the puller is the preferred way to go, rather than beating the part using a "pickle fork". Plus, if you don't have a new rubber boot you can use it over, with the pickle fork, it's usually ruined.
02-17-2020, 03:52 PM | #9 |
Yes they are great mine was $12. from Harbour Freight, excellent tool.!
02-18-2020, 04:20 PM | #10 |
Got a couple PMs asking who made it. It has KD 3918 stamped on it. Forgot to add that it often takes a good rap with a heavy bludgeon to unseat the taper. The thing also take a beating and comes up smiling as if to say "you couldn't hurt me if you tried" It is one tough tool.
