01-11-2015, 04:07 PM | #1 |
Aerostar Springs and the bump stops?
For all of you running the Aerostar Coil Springs on a 54-56 Ford Passenger Car front end, did you keep, cut, or lose your bumpstops since the frame will sit a few inches lower?
Lancaster, California Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! |
01-11-2015, 05:39 PM | #2 |
Re: Aerostar Springs and the bump stops?
My birds a little lighter, and the engine a bit back, but I didn't change anything but the springs, initially. Since the Aerostars are a progressive rate, you get a great ride on the little bumps, but the big ones get into the higher rate and the car never bottoms. I know, never say never. I think I saw something in your post about the Mustang (?) rubber seats that are going to raise them a bit? If so, I don't think it'll be a problem even with more weight up front.
01-11-2015, 06:30 PM | #3 |
I cut mine on the Ranchwagon, figured it would be better to have a little cush then a clunk.
01-11-2015, 08:36 PM | #4 |
The progressive rate is the beauty of the Aerostar springs. I have the stock bumps on my '59, but having it running is still months away.
01-14-2015, 01:43 PM | #5 |
I cut the ones on my 56 in half to have more travel. I had them out for a while when I had blocks instead of the Aerostar springs and definitely had a hard hit! But, the stops are too tall to have much travel full height with the new springs.
01-22-2015, 06:27 PM | #6 |
01-22-2015, 06:39 PM | #7 |
Does anyone have a before and after with Aerostar springs on a 55 - 56 fairlane ( townie pref) ?
01-23-2015, 01:26 AM | #8 | |
01-24-2015, 07:43 AM | #9 |
You can lower these cars without buying new springs or shocks and retain the smooth ride, all you need are 12 high tensile bolts and some flat bar. Remove the 6 rivets on the lower control arm spring retainer ( I had the control arms off when I did this), once this is done cut the flat bar to length ( I use 3mm thick buy 25mm wide ) using the spring retainer as the template, place the flat bar pieces between the spring retainer and control arm and re fix it using the high tensile bolts, I have found that with all the standard springs and using 2 of the 3mm spacers (6mm) it drops the front by about an inch, Obviously the more spacers you use the lower it goes... I put up to 20mm ( used ally bar) and it dropped it two and a half inches which then hit the bump stops and was too low for me .... The Bueaty of this way is you can adjust it to the correct hieght you want with out worrying about having to buy different springs you can change the spacer hieght when the control arm is fitted.
01-25-2015, 02:00 AM | #10 | |
01-25-2015, 06:04 AM | #11 |
I suppose if all depends on how low you go and how much travel your left with, with the blocks you pictured the control arm bump stops would be pretty close to the chassis, I tried that size!!!... See picture, so I decided on the 6mm spacer with standard springs as you still have the travel and smooth ride, I used Monroe gt gas reflex shocks which firmed up the ride nicely
image.jpg |
01-26-2015, 11:14 AM | #12 |
Blackpearl, Your car is upside down!! Oh, I see now, your from Australia. Anyway, I've had my '55 Ranchwagon both both setups and the Aerostar springs are MUCH better. Reason being Aerostar springs are progressive woond and the stock spring is straight wound. |
01-26-2015, 12:11 PM | #13 |
The sway bar end links do not look quite right to me,here is how to measure for the correct length:http://www.energysuspensionparts.com...-End-Links.asp When you change ride height this should be checked.
01-27-2015, 12:17 AM | #14 |
Thank you gentlemen !
