Old 09-21-2017, 11:10 AM   #1
ole39
ole39's Avatar
Default crank question
how far can you safely turn an 8ba crank for a lightly modified street cruiser?
ole39 is offline   Reply With Quote
Old 09-21-2017, 11:14 AM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: crank question
.030
You are not far from me, it seems. If you need a crank let me know, I have plenty.
Old 09-21-2017, 12:16 PM   #3
Kahuna
Kahuna's Avatar
Bearings were available up to .050" years ago.
Don't think they are around any longer
Kahuna is offline   Reply With Quote
Old 09-21-2017, 12:23 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
I am amazed at the concern at .030,.040, yet not much concern when 1/8 is taken off to make a stroker----- its more important that the crank grinding wheel has the correct radius--- but it takes time and grinding wheel loss $$ to change radius
Old 09-21-2017, 01:54 PM   #5
Paul Bennett
If you seriously want power, check into SCAT srankshafts ... not as expensive as you might think and available to well over 4".
Paul Bennett is offline   Reply With Quote
Old 09-21-2017, 02:24 PM   #6
Seth Swoboda
I agree with this analysis. You can buy a stroked crank for not much more than finding a good original Mercury crank.
Old 09-21-2017, 02:27 PM   #7
GOSFAST
GOSFAST's Avatar
If brgs are available don't worry too much about the under-size! (I do keep .030" unders, rods and mains, on the shelf for the 8BA's)
Under no circumstances would I recommend a Flathead Scat crank, only due to the labor involved making it work. He would also have to change pistons and most likely the rods? Definitely the pistons not sure about rods??
Thanks, Gary in N.Y.
P.S. In our opinion the best rotator kits consist of an Eagle crank, Scat rods, and Ross pistons (moly rings). It's just about all we will handle in "strokers" for the most part! Some exceptions, but few really!
GOSFAST is offline   Reply With Quote
Old 09-21-2017, 05:21 PM   #8
flatjack9
flatjack9's Avatar
It's quite common to offset grind rod journals on Merc cranks down to 1.999 and use full floating bearings.
Old 09-21-2017, 06:35 PM   #9
KiWinUS
KiWinUS's Avatar
Gary has nailed it once again with his great advice.
He has just just helped & supplied a good friend of mine from the pacific NW with a kit & he couldn't be happier with al the help Gary gave him the first class service & how it performs.
He also loves the KiWi-L100 camshaft.
Cheers
Tony
