05-11-2022, 12:53 PM | #1 |
56 sedandeliver rear mud flap.
So working under the car and notice one side has the mud flap/guard and the other does not. On the side that does not I see nowhere any mounting points similar to the other side. Did these cars have them on both sides? Left pic is drivers side, right one is pass side. Thanks
05-11-2022, 04:49 PM | #2 |
Re: 56 sedandeliver rear mud flap.
To protect the fuel filler?
05-11-2022, 05:19 PM | #3 | |
Below is an ILL of the car's lower sheet metal - Look @ PN 27882. It is the inner and outer wheel-housings together as an assembly.
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 05-11-2022 at 05:38 PM. |
05-11-2022, 06:09 PM | #4 | |
Wheel housings are on and in great shape. The one on the drivers side could be to protect the fuel filler since there is not on the pass side. This flap attaches to the inner rear sheet metal with screw and to the floorboard at the top to a L bracket welded to the floor. Neither of these are on the pass side. The drivers side is about 4 inches behind the wheel housing. May just make one if for no other reason then keeping road crap off the rear. Last edited by 56sedandelivery; 05-11-2022 at 06:14 PM. |
05-11-2022, 06:12 PM | #5 | |
Who knows, it might have been covered in a PARTS SPECIAL LETTER.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
05-12-2022, 05:21 PM | #6 |
05-13-2022, 01:14 AM | #7 | |
Doesn't the wheelhouse and extension encapsulate ... ... the rear tire? This protects the fuel filler pipe? Dave?
05-14-2022, 04:04 PM | #8 | |
The wheel housing only cover the tire down to the floorboard and that is fairly high on the SD. There is no extension. I think the drivers side is to protect the filler as has been noted. Probably never had anything similar on the pass side. |
05-15-2022, 01:40 PM | #9 |
Interesting. I'm going to check on my '54 Ranch Wagon and see what it looks like.
05-15-2022, 03:24 PM | #10 |
I have a '55 Courier sedan delivery and it never had a splash shield in front of the gas tank filler neck and there isn't one on the passenger side either. looked real hard for some divets in the area where your pan is shown and it is flat and smooth as a board. Maybe it was something that was added in the '56 model year.
05-15-2022, 07:10 PM | #11 |
PN 27856 is the extension I am describing -
What I am trying to figure out is the front of the RH wheelhouse. Is that a cut-out section in the front of it?
05-15-2022, 09:33 PM | #12 |
Lousy pic. Will try and get a better one. The grey area is the wheel housing. The darker black is the floor board.
Better pics. Inside of car and under car. Hope this helps. Last edited by 56sedandelivery; 05-16-2022 at 10:10 AM. |
05-16-2022, 08:44 PM | #13 |
I get why you ask that. It's an optical illusion. What you are really seeing there is the back of the wheelhouse where it meets with the flange of the floorpan. His camera is pointed somewhat upward, rather than straight toward the front. We are not even seeing the front of the wheelhouse in that photo. It is out of the camera view, and even if he could shoot a photo straight forward, the tire would mostly block the view of the front of the wheelhouse.
05-21-2022, 07:32 AM | #14 | |
Guess I need to look under one ...
