Old 05-09-2022, 07:57 PM   #1
Steve in Denver
Steve in Denver's Avatar
Default 1957 Ford front backing plate diagram
A friend is looking for a diagram of how the front backing plates should look for his '57 drop top. He thinks he has two right side backing plate assemblies.
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 05-09-2022, 10:18 PM   #2
fordor41
fordor41's Avatar
Default Re: 1957 Ford front backing plate diagram
Only thing I can think of is the adj. star wheel would be in wrong position compared to the adj. slot (reverse the adjuster). bet L & R are the same if they both fit
fordor41 is offline   Reply With Quote
Old 05-10-2022, 03:33 AM   #3
KULTULZ
KULTULZ's Avatar
Exclamation Re: 1957 Ford front backing plate diagram
Both plates (L&R) are the same...
I did not know that. It explains a few things such as self-adjusters refit.
File Type: jpg PLATE ASSY (2012) - FRT BRAKE CARRIER.jpg (19.8 KB, 22 views)
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 05-12-2022, 06:06 AM   #4
KULTULZ
KULTULZ's Avatar
Arrow Re: 1957 Ford front backing plate diagram
To further expound on the subject -
1954-56 FORD used L & R
1957-60 FORD used the same plate both sides
1961-64 FORD used L & R w Self-Adjusters Feature
- WHY IS IT ... -
Old 05-12-2022, 06:52 AM   #5
Steve in Denver
Great, thanks everyone, I will pass the info along.
Steve in Denver
Old 05-12-2022, 07:33 AM   #6
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 1957 Ford front backing plate diagram
You are more than welcome. If you don't mind, can you post his reaction to the news?
How many did I work on and it never dawned on me ...
- WHY IS IT ... -
Old 05-12-2022, 07:35 AM   #7
KULTULZ
KULTULZ's Avatar
You're smart ...
I kept wondering why it was described as the adjuster being reversed on a SELF-ADJ SYSTEM being added ...
- WHY IS IT ... -
