09-04-2020, 09:14 AM | #1 |
1958 Ranch Wagon Front Disc Conversion
Hi All
I am on a very limited budget and looking to upgrade the front brake system on my ranch wagon to a disc brake setup. Can anybody point out a complete kit to do the job for me without breaking the bank? Any help would be much appreciated Many Thanks DAZ Sent from my iPhone using Tapatalk |
09-04-2020, 10:52 AM | #2 |
Re: 1958 Ranch Wagon Front Disc Conversion
Dont know what break the bank is but this is where I got my 56 conversion.
https://www.mpbrakes.com/ |
09-04-2020, 02:23 PM | #3 |
Another source is ECI (Engineered Components Inc) in Connecticut. Lot of brake conversion kits
09-04-2020, 10:09 PM | #4 |
I don't know what " break the bank " is either, but have you thought about just a good rebuild on the drums? IIRC, those Ford wagons had 11"x2.5 front drums, and they were pretty well up to the job. If your towing in heavy traffic at 70, maybe not so much, but for driving they're fine.
Decent lining and proper fitment (to the drum) makes a huge difference over poorly replaced drums/shoes. Finding someone to do that can be difficult, but including your location might help. I've done more than one disc conversion that wasn't much of an improvement. Poor quality master cylinder, cheap brake pads, etc. Cheap all too often turned out to be not so cheap. I know there are others here who can recommend specific parts, let's hope they chime in. |
09-04-2020, 11:42 PM | #5 | |
09-05-2020, 05:26 PM | #6 | |
09-05-2020, 07:31 PM | #7 |
There is a company in Connecticut that installs linings on your shoes that provides better braking. Don't have the name right now.
09-10-2020, 02:29 AM | #8 |
Thanks to all you knowledgeable people out there who help people like me!
After reading everything, I am going to stick with the factory setup and make sure I have the factory setup perfect. Regards Daryn Sent from my iPhone using Tapatalk |
04-05-2021, 07:17 PM | #9 |
I changed my ElCamino over to front disc and it ended up being about $1,000 with new dot4 fluid and wheel cylinders.
Performance Suspension Technologies. Long-time hemmings advertiser. Last edited by Gene F; 04-15-2021 at 07:03 PM. Reason: typo found |
04-06-2021, 01:24 AM | #10 |
IN MY OPINION ONLY To keep it all FORD and not to have to look for GM parts for future service, either the GRANADA swap or the the TORINO swap. Both require donor spindles. You simply use all components from the donor to the 58. No CHI-COM and no DIALING FOR DOLLARS ADJ PPV. As for relining drum brakes - https://www.porterfield-brakes.com/m...akes/R4-S.html
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
04-12-2021, 07:49 PM | #11 |
I used Granada spindles on my 56 wagon. All you need to do is ream out the bottom hole with a 6 degree reamer. End of story.
If brains were wire, some couldn't short circuit a firefly |
