Old 02-09-2021, 11:07 AM   #1
kwisor
kwisor's Avatar
Default 1923 roadster running bad need help
hello
my 23 has started to run bad i had the head gasket replaced and all the carbon cleaned, it idles fine but back fires ans loss of power. i do not have a compression gauge. i removed the no 1 plug and it was black with carbon. i have fire to all cycl. i have a rebuilt carb and good gas flow. what to i need to do from here
thank you
kevin
kwisor is offline   Reply With Quote
Old 02-09-2021, 12:25 PM   #2
J Franklin
J Franklin's Avatar
Default Re: 1923 roadster running bad need help
What was the reason to change the head gasket? Have you adjusted the carb to run a bit leaner?
Old 02-09-2021, 12:33 PM   #3
kwisor
kwisor's Avatar
the gasket had a leakes of antfreeze in the rt rear corner no leak into the oil
kevin
Old 02-10-2021, 11:07 AM   #4
rickd
Did you make any changes to the carb mixture adjustment while doing your work? Spark plug wires re-connected correctly? Sounds like its running way too rich. When things like this stump me I slow it down and go back to the basics and recheck spark, fuel and air(mixture) especially when the car was running well previously.
rickd is offline   Reply With Quote
Old 02-10-2021, 11:56 AM   #5
Will N
Will N's Avatar
Maybe check for a vacuum leak at the intake manifold. I imaging you remove the manifolds when the head was removed. Did you use a new manifold gasket? Did you tighten the nuts down nice a tight?
Will N is offline   Reply With Quote
Old 02-10-2021, 03:02 PM   #6
jetmek
Bent a valve removing otr installing the head?
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 02-10-2021, 05:00 PM   #7
J Franklin
J Franklin's Avatar
That happened to a friend. He and I were so careful and yet something touched a valve and it had to be replaced.
Old 02-11-2021, 12:41 PM   #8
redmodelt
redmodelt's Avatar
Is it back firing out the carb or exhaust? No 1 plug is the coldest so what do the rest of the plugs look like? If the rest are black from carbon, then yes running too rich. Which type/brand of carburetor are you using? Turn the spray needle down till the engine starts to stumble and open a bit. May need a bit more adjusting when you are driving. Are you using the copper crush rings or the fiber type 3 in one gasket on the manifold? Google "MTFCA checking for vacuum leaks"
