10-18-2018, 06:41 PM | #21 | |
Re: Up-date on 41 front wheel shimmy
If you are going to separate the hubs and drums you will need to get the special tool to cut the swages off the studs to let them come apart. you can't just press them off. |
10-20-2018, 10:43 AM | #22 |
The hubs and drums I have are not like the original's they are made to be seperated without cutting the studs free. Al
10-20-2018, 10:59 AM | #23 |
When you say steering stabilizer are you talking about one of the VW type hydraulic stabilizers? It should be mounted between the tie rod and wishbone.
10-20-2018, 05:49 PM | #24 |
Yes that's the kind I had on the car, but removed it while trying to find out what all could be wrong causing the shimmy. When the weather let's me I'll change the location of the tire's to see if I can get it better, then maybe re-install the stabilizer if need be. It doesn't have a clamp on the end to fit to the wishbone, another FB'er gave me a place that has the mounting clamp. Al
10-20-2018, 10:11 PM | #25 |
Just for the heck of it. What's your toe out/in settings?
https://www.earlyfordv8.org/forum/vi...=18&topic=3368 My 38 does 70 with ndt tires and about 1/8" toe in. Set it myself so you know it's accurate. . Last edited by Tinker; 10-20-2018 at 10:21 PM. |
10-21-2018, 10:08 AM | #26 |
10-21-2018, 10:41 AM | #27 |
Al, a tip on how to set your toe in very accurately: With your car on jack stands, spin each front wheel while holding a white chalk against the treads, followed by an ink pen fine line over the chalk line. This will determine a true line, not wobbly as would the treads themselves often do.
For the actual measurement between tires, a 1" x 2" with a nail in one end and a 6" rule attached to the other works well, supported by a light framework on both sides. I've used just one, but it occurs to me now that if you made two identical, it would avoid the hassle of moving it front to back of tires multiple times till you were satisfied with the adjustment. Most guys I know set the toe in at 1/8". 1/4" is considerably more than required, and will wear out your tires rapidly.
Alan |
10-21-2018, 11:26 AM | #28 |
Thanks for the tip, I guess that if I jacked the car up by the frame it would let the axle drop enough to get to the back of the tire better. I had a front alignment shop set the toe in, they et it 1/4" and at 50mph it almost shook the front fenders off. I've set it back some where around 1/8" and it's better. Had all 4 new Coker tires road forced balanced, doing better now. Need to know what the 2 front tires readings were after RFB, the back ones were right side 10#, left side 20#, if I can find out what the front ones are maybe switch them around and get better results. Al
10-22-2018, 01:30 AM | #29 |
Another what the heck. How's your shock setup? It does dampen the suspension.
10-22-2018, 03:05 PM | #30 |
Go back to the front end shop and have them set it at 1/8"??
Paul in CT |
10-22-2018, 05:15 PM | #31 |
I think you need to have the vehicle weight on the tires to get an accurate measurement.....Mark
“I guess that if I jacked the car up by the frame it would let the axle drop enough to get to the back of the tire better.“
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
10-22-2018, 07:11 PM | #32 |
I made this and did the toe in myself . no tyre ware [ and my king pins aint good ]
When you have sorted your problem fit a steering damper as cheap insurance.
10-23-2018, 08:14 AM | #33 |
What does the other end look like? How do you use it? I ask because I used strings against the sidewall like I would have on a motorcycle. I am wondering how the beam is referenced to the vehicle.
10-23-2018, 01:18 PM | #34 |
Weather here is terrible and I can't do anything now,(rain-rain-rain ) is there still a sun? About to go stir crazy. Al
10-23-2018, 01:24 PM | #35 |
My dad used a 1" X 1" with finishing nails driven through, sticking out on the other side about 1/2". Marked the front then compared the distance on the back of the tire. It was an old 36 Chevy with hydraulic knee action front end, worst idea GM ever had. All
10-23-2018, 01:24 PM | #36 |
Same as described in my post # 27.
Alan |
10-23-2018, 07:37 PM | #37 |
Ok from memory I started the string line to get close. But this works by jacking up the wheels spin them and use chalk down the middle and then get a fine nail to score and give you a fine and clean line to work to. next move the car back and roll it forward a few meters [ so the wheels track]. You then slide it too the back the wheels find the line you scored on the tyre. Adjust and put the points right on the lines you've scored on the tyres, lock it off . Now move to the front put one point on one line of a tyre and then you should have your 1/8" or 1/16" [whatever the setting should be ] more on the other tyre so the tyre is in. Adjust to get it, try a few times.
10-23-2018, 08:00 PM | #38 |
delete
10-24-2018, 11:21 AM | #39 |
The shocks are, or look like they have been rebuilt. They are round huidilla (misspelled) don't know how to set them for best results. The pointer on front shocks turns 360 deg. while the rear ones only turn 180 deg. stop to stop. Still need to adjust them some more to see if that helps. Al
10-25-2018, 09:45 PM | #40 | |
