Old 08-30-2020, 08:47 PM   #41
Pete
Pete's Avatar
Default Re: Trailer hitch
Originally Posted by McMimmcs View Post
Gg
Great if you are into hot rods! To each his own.
Roger on that.....I did the stock A thing for 50 years so I put in my time...lol
Old 08-31-2020, 06:39 PM   #42
Russ B
... but on the other hand, why buy a trailer hitch from any manufacturer that says don’t use his hitch to pull a trailer?
Russ B is offline   Reply With Quote
Old 08-31-2020, 06:42 PM   #43
Russ B
If the manufacturer distinctly says not to pull a trailer with his hitch, why would you risk everyones safety and defiantly do otherwise! Doesn't seem very logical or smart to me!
Old 09-01-2020, 05:09 AM   #44
trulyvintage
trulyvintage's Avatar
Lightbulb The Model A Is Not A Tow Vehicle
The Model A Is Not A Tow Vehicle 🛑
Jim
trulyvintage is offline   Reply With Quote
Old 09-01-2020, 06:40 AM   #45
McMimmcs
McMimmcs's Avatar
Default Re: The Model A Is Not A Tow Vehicle
Jim
I couldn’t agree more!
Old 09-01-2020, 07:56 AM   #46
Licensed to kill
Licensed to kill's Avatar
[IMG][/IMG]
Licensed to kill is offline   Reply With Quote
Old 09-01-2020, 08:02 AM   #47
Hoogah
Hoogah's Avatar
I think the Keely trailer has been discussed here before. Great pair!!
That coupe is set up for heavy duty towing, isn't it?
Hoogah is offline   Reply With Quote
Old 09-01-2020, 08:21 AM   #48
Licensed to kill
Yes. Military wheels on the back and some super skookum springs it would appear. I wonder why they put the axle so far back creating so much hitch weight??. Should pull nice and straight though.
Old 09-01-2020, 01:24 PM   #49
trulyvintage
Thumbs down Irresponsible & Negligent
Originally Posted by Licensed to kill View Post
[IMG][/IMG]
Nice Pose 👍
Other than that - to attempt to actually tow with that set up is:
Irresponsible
Negligent
Criminally Negligent
The vehicle is not rated to tow the trailer
The vehicle cannot safely stop 🛑 with the trailer
The operator could be found criminally negligent
if an accident occurred 🙄
No insurance company will knowingly issue a policy
or honor a claim for that set up
Jim
Old 09-01-2020, 01:53 PM   #50
Licensed to kill
Default Re: Irresponsible & Negligent
Nice Pose 👍
Irresponsible
Negligent
Jim
I am not intimately familiar with this particular rig, only know what I see in the picture. I hope that you are and that you are not presenting such a list of assumptions as fact. Tow trucks of that vintage towed vehicles with no additional brakes on the vehicle being towed. The trailer in the picture COULD have vacuum brakes which would make it better than zero additional brakes like a tow truck. It's unlikely IMO that this car has a stock rear with stock gears (3.78) as the clutch is simply not big enough to handle the load. That, coupled with the rear wheels and the stance suggests to me that the car may be outfitted with a heavy diff with VERY low gearing, much like an AA which would increase it's tow capability and reduce it's top speed making it MUCH safer than a "stock" coupe. Of course all of this is pure speculation as i am not familiar with the cars specs as it sits. My point is that, unless you KNOW this car and exactly how it is set up, what you posted is conjecture and should not be presented as fact.
Old 09-01-2020, 02:32 PM   #51
trulyvintage
Thumbs down Tow Vehicle Footprint
I don’t have to write an Essay 🙄
The trailer is equal or greater in weight - mass - length
to the tow vehicle 👀
There is no way that tow vehicle can safely stop
that trailer at operating speed under normal conditions
let alone in an emergency 🛑
Common Sense 👁
Jim
Old 09-01-2020, 02:47 PM   #52
trulyvintage
Exclamation Every Day
I have been on the road hauling just about every day since 2006 😏
I See Stupid Every Day 👀
When you get on a public road and endanger
someone else’s Life .... 😡
That is where your “ freedom “ and “ creativity “ end 🛑
Taken about an hour ago in Wyoming:
Jim
File Type: jpg 70A370BA-2D26-4183-B7A9-4E8FCAC0C162.jpg (42.1 KB, 102 views)
Old 09-01-2020, 03:06 PM   #53
CHuDWah
CHuDWah's Avatar
Given Mac's disclaimer, there's been quite a bit of debate in this thread over the sturdiness of their hitch. But if one actually reads the disclaimer, it says, "Since factory Model A's are very light, have a short wheelbase, and mechanical brakes, adding significant weight or trailer towing are not recommended." It does not address the suitability, or lack thereof, of the hitch itself for towing. Whatever, I know some intrepid souls tow with their A and get away with it. But I would not for exactly the reasons Mac states.
CHuDWah is offline   Reply With Quote
Old 09-01-2020, 10:31 PM   #54
warhorseracing
warhorseracing's Avatar
When the Model A was produced there were very few paved roads in the U.S. Roads and bridges were not even dreamt of to carry the 80,000 Lb. loads permitted on today's roads. Even though they are slowly being replaced the bridges built prior to 1920 were never designed for that weight let alone imagined by the design engineers yet they were substantial enough to still be in use today. Was a Model A capable of towing? What has been done and what is ethical are two different apples or oranges.
warhorseracing is offline   Reply With Quote
Old 09-02-2020, 08:52 AM   #55
Licensed to kill
Default Re: Tow Vehicle Footprint
I don’t have to write an Essay ��
to the tow vehicle ��
That is the case in the vast majority of towing from commercial transport to RV's. NO I am not suggesting that the car/trailer in question is as suitable for towing as a Peterbilt, just pointing out that pulling a trailer that it longer and heavier that the tow vehicle is not uncommon. Also, in the case of the car/trailer in question, the rig will tow incredibly straight with all that hitch weight so the weight difference between the car and trailer is not a factor other than braking.
let alone in an emergency ��
Common Sense ��
Jim
You could be right. However, you can't make that assumption and present it as fact unless you KNOW how it is actually set up. Do you KNOW that the trailer has no brakes?. Do you KNOW what the "operating speed under normal conditions" is?. If the car is geared so slow that top speed is 25MPH and the trailer has vacuum or electric brakes, then it could be quite safe. IF, OTOH, the car is going to be travelling 50MPH like a stock A coupe would (unlikely that it even could pulling that trailer) and only has the factory car brakes and no brakes on the trailer then, yes, I agree 100% with your supposition. My point is that there is no way to make that determination simply by looking at that picture. BTW, you are right. We see scary stuff on the highway every day. However, it is very rare, in my experience, that the scary stuff is as nice, neat and tidy as the keely rig in the picture. the scary stuff is usually cobbled together junk.
Old 09-02-2020, 09:52 AM   #56
Hoogah
Hoogah's Avatar
I don't need much of an excuse to re-examine these photos of the overloaded farm vehicles from the dustbowl migration (although I think the Hudson ones are recreated for the Grapes of Wrath movie). I wonder what sort of hitches they used for their trailers? Home-built is my guess.
Old 09-02-2020, 04:05 PM   #57
trulyvintage
Lightbulb The Real World
Sorry I don’t live in Canada
I Live In Reality
Jim
