Old 08-29-2020, 10:05 AM   #1
zaugger
zaugger's Avatar
Default Replacing fuel shut off problem
Hey guys! I am tryin to remove my fuel shut off valve on a 29 Tudor. It is very hard to turn the valve when tryin to remove it, and it has me second guessing the direction for removal. Any ideas/trick of the trade would be greatly appreciated. Thanks!
zaugger is offline   Reply With Quote
Old 08-29-2020, 10:14 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Replacing fuel shut off problem
Standard off as any nut/ bolt!
www.whidbeymodelaclub.com
Old 08-29-2020, 10:36 AM   #3
stevests
stevests's Avatar
Righty-tighty - Lefty-loosey.
stevests is offline   Reply With Quote
Old 08-29-2020, 10:41 AM   #4
Jacksonlll
Jacksonlll's Avatar
It’s a pipe thread, it should come out without breaking anything. Good luck.
Old 08-29-2020, 10:41 AM   #5
zaugger
zaugger's Avatar
Thanks. That’s what I was doing, of course. Just super tight.
Old 08-29-2020, 10:46 AM   #6
J Franklin
J Franklin's Avatar
Sometimes a shot of WD-40 or such helps.
Old 08-29-2020, 02:39 PM   #7
McMimmcs
McMimmcs's Avatar
Always easy to remember, thanks!
Old 08-29-2020, 07:16 PM   #8
stevests
stevests's Avatar
You are most welcome !
Old 08-29-2020, 10:42 PM   #9
30 Closed Cab PU
With at least one exception - certain year cars lug nuts,. I will never forget my dad getting enjoyment of me trying to get the lug nuts off a 60s car (think it was a Dodge). Was lucky I did not twist the lug bolt off. He finally told me that my car had reverse threads on one side of the car.
Old 08-30-2020, 09:56 AM   #10
stevests
stevests's Avatar
I have left & right hand lug nuts on the Michelin disc wheels on my wife's Model T Fire Chief's rig - I was directing my statement at the O.P.'s situation.
Old 08-30-2020, 10:43 AM   #11
30 Closed Cab PU
Sorry, I meant to only add to the discussion in case others were unaware. Probably should not have quoted you and phrased my post differently.
Old 08-30-2020, 11:09 AM   #12
katy
katy's Avatar
Don't forget to drain the gas out of the tank before removing the valve, also raise the RH side of the car a bit.
Old 08-30-2020, 11:17 AM   #13
Ernie Vitucci
Good Morning...Depending on the type of wrench you are using, a pipe extension will allow you to put more torque on the valve under the dash without having to hammer on it or try to jerk the wrench...steady increasing pressure will usually finally make it move...Ernie in Arizona
Old 08-30-2020, 11:18 AM   #14
The Master Cylinder
The Master Cylinder's Avatar
AA Trucks have left handed threads on the dually rear wheels . And yes, Chrysler products also had left handed threads on one side and right handed threads on the other.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
