08-01-2013, 08:23 PM | #1 |
Temperature Sending unit question
On a two prong temp sending unit, does it matter what prong the wire to the dash guage attaches too? Long one or short one! Thanks
08-01-2013, 08:47 PM | #2 |
Re: Temperature Sending unit question
Doesn't matter. It's just a switch like a light switch. Current can go either way.
Here's a diagram of the system to better understand how it works: Close up diagram:
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 08-01-2013 at 08:52 PM. |
08-01-2013, 09:15 PM | #3 |
So it looks like one side gives temperature and the other is just an on/off switch?
08-01-2013, 09:25 PM | #4 |
Yes, when the 2 wire one reaches the set temperature the gauge will peg hot ---it is one way to know which side has the problem, if the gauge suddenly goes "hot" it is usually the 2 wire side, if it goes hot gradually it is usually the 1 wire side
08-01-2013, 09:30 PM | #5 |
Based on the picture, I would hook the gauge to the long one. just in case.
08-01-2013, 09:45 PM | #6 |
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
