09-12-2020, 09:49 PM | #1 |
adjusting 39 Ford pickup shocks
I have the shock heads with the pointer and chisel mark for adjusting. What does "increase" and "increase" mean." Increase the amount of dampening?
09-12-2020, 10:58 PM | #2 |
Re: adjusting 39 Ford pickup shocks
I'm not sure if mine are the same as yours, but one of mine was set too harsh. Expereminting I found turning it CCW made it work better. Mine are the round type, sometimes called Hudni. Al
09-13-2020, 05:50 AM | #3 |
Turn CW to increase resistance and CCW for less. Suggest you take a note of your start point and only move about 1/32" at a time.
09-13-2020, 11:07 AM | #4 |
thanks. do all four need to be the same?
Can I use the bounce test to check changes? Meaning climb on the bumpers and bounce the car at the corners? I'm still too stiff and tired to dismount the shocks |
09-14-2020, 11:29 AM | #5 |
Ms. Sandy helped me with the bounce test. I was the bouncer person and she the safety officer. She was not impressed with an 83 years young bouncing of the bumpers and yelling "Giddy-up!)
The pickup failed the test passenger side front shock and driver's side rear softer than the another two. I'm thinking I increase the settings on both? |
09-15-2020, 02:58 AM | #6 |
Thanks |
09-15-2020, 06:11 AM | #7 |
The small adjustment usually makes a very big difference. are the shocks full of fluid? Go ahead and move the pointer 3/8" When were the shocks rebuilt?
09-15-2020, 11:06 AM | #8 |
shocks are full and don't leak. I got them from here and there. If I found a stronger one, I swapped it in place. During set up, i move the pointers on all four to the factories' chisel mark. The right front and left rear are soft, so I want to readjust them to match in performance. (I painfully learned that post war shock ears are a different size from prewar.) Thanks for your help. I will report progress.
09-15-2020, 09:12 PM | #9 |
Next challenge is balancing the shocks and increasing the resistance. This morning the pickup failed his “Bounce and return test.”
I have approval from Fordbarn to adjust the shock needles. To start, all four are adjusted to the factory chisel marks. The right front and left rear shocks are soft. I added 50deg. To the right front which helped. The left rear pointer and shaft freely rotate, so I decreased the pointer trying to match the bounce across the rear end. Seems the right thing to do. I suspect the adj. paddle shaft is broken.) Can I replace the valve in the shock with the shock installed in the car?? |
09-15-2020, 10:30 PM | #10 |
Hope this is of some help.
09-15-2020, 11:23 PM | #11 |
Clem, When installing newly rebuilt shocks myself, I clamped both in a large bench vise (not so easily), with both arms parallel pointing up. One hand on each, I push/pulled and adjusted to make them match. Your bounce method may be more useful than my vise test was!
Alan |
09-16-2020, 12:02 PM | #12 |
Does anyone ever flush out a shock. if it is dry, I understand it is probably shot. If it is closed is there any need to flush? I found one of my extras is a left rear for my 39, but when I move the arm there is a terrible grinding sound inside. I poured a little lube out and it is dark Brown. I'm thinking the innards are shot. When I adj.it full increase, the shock locks up tight.
Clem always learning |
09-24-2020, 11:47 PM | #13 |
I have flushed out the shock 6 times using Evaporust. I still get tiny black flakes of rust. The grinding is gone, but there is not much resistance to the arm motion. Does the valve and stem just unscrew? So far I can't remove it.
09-26-2020, 09:14 AM | #14 |
[QUOTE=Clem Clement;1934998]I have flushed out the shock 6 times using Evaporust. I still get tiny black flakes of rust. The grinding is gone, but there is not much resistance to the arm motion. Does the valve and stem just unscrew? So far I can't remove it.[/QUOTE
Clem, save yourself a LOT of frustration and have the shocks rebuilt professionally. You appear to drive your vehicles and hey, you can't take it ($) with you... enjoy it (rebuilt shocks) now. These shocks don't disassemble easily and require special fixtures to R&R.
09-27-2020, 11:22 AM | #15 |
Thanks. I'm just playing and learning. I can't seem to unscrew the pointer and seal nut. They unscrew and then jam??
