01-04-2015, 01:16 AM | #1 |
Changing Differential Oil
Today I went through the frustrating and infuriating experience of changing the differential oil in my '31 Model A. The old oil was, of course, easy to get out, but getting the new stuff back in was another matter entirely. After experimenting with three different arrangements of tubes and funnels, one of which dumped a cup of the thick oil on my head, I finally arrived at a solution with a small funnel and a short length of tube that barely worked, taking a very long time to finish the job. The tube was just small enough to fit into the filler hole, but too small for that thick oil to flow at more than a trickle. But at least it's finished.
I know there's got to be a better way to do this. What works for you? |
01-04-2015, 01:38 AM | #2 |
Re: Changing Differential Oil
Nice look, think I'll pass tho. I use a squeeze bottle like you buy regular gear oil in.
01-04-2015, 01:46 AM | #3 |
If you are using the heavy stuff, take the squirt bottle you'r using , heat the bottle in a big pan of water, to get it thin enough to squirt it into the place were you want it to go.
01-04-2015, 01:49 AM | #4 |
Swueeze bottle, big tube in place of the little nozzle.
01-04-2015, 01:54 AM | #5 |
I use lever action grease gun
just put oil in instead of grease |
01-04-2015, 02:10 AM | #6 |
With several bottles on hand it is easy enough to have a full bottle ready to go when there is need. Tom Endy |
01-04-2015, 03:32 AM | #7 |
#2 & #6 works easily for me also
01-10-2015, 12:56 PM | #8 | |
Like Tom and others the squeeze bottle the 600W comes in was quick and easy to put in the pumpkin for me.
John from Kapowsin T&A Guy |
01-04-2015, 10:21 AM | #9 |
I think your car marked it's owner :-) I used a length of tubing and funnel heated container
600w flows like molasses at 40*F and I still made a mess :-( |
01-04-2015, 10:24 AM | #10 |
all you need is a bottle top like this and its easy even cold
it works for the trans and steering box also |
01-04-2015, 10:38 AM | #11 |
Thanks. I imagine I could find the squirt cap at any parts store.
01-04-2015, 11:04 AM | #12 |
I use a pump that is used for my outboard motors lower unit lube, it works every time and is very clean. Check your local boat supply. JMHO. Jim.T.
01-04-2015, 12:14 PM | #13 |
A pump oil can with the small nozzle unscrewed also works. Most of the time I use the plastic bottle like Mitch showed, or an empty ketshup bottle.
01-04-2015, 05:04 PM | #14 |
I know I am dating myself, but after 79 years that doesn't matter.Years ago on the old cars around the stations, for years we used the hand held suctions with a rubber hose to suck the oil out of the oil filters. I use that on my A,s. It works great, suck the 140 or 90 out of the bottle, stick the hose in the differential or transmission and push.
01-04-2015, 05:23 PM | #15 |
Greasy kid's stuff ....
01-04-2015, 05:45 PM | #16 |
01-04-2015, 11:09 PM | #17 |
All PepBoys, Harbor Freights, and such offer a suction pump with about a one liter capacity. Keep your 600W in the house during the winter, suck a pint out of it with the suction pump and then pump it into the rear end to almost the bottom of the filler threads.
Maybe this link to Harbor Freight will work. http://www.homedepot.com/p/Plews-Suc...g&gclsrc=aw.ds Last edited by Bruce Adams; 01-04-2015 at 11:20 PM. Reason: x |
01-04-2015, 11:14 PM | #18 |
my experience is those cheap suction guns dont last and before you know it the fluid gets behind the diaphram and then comes out the backside of the gun and loses its suction power. i purchased a couple lincoln brand high quality ones and they lasted a little longer but yes its another option
05-11-2015, 10:25 PM | #19 | |
01-05-2015, 02:00 AM | #20 |
Ditto what Mitch just said.
I bought a quality looking older suction gun last summer for a buck at a swap meet, but haven't tried it yet. Every one I've had in the past was a leaker. |
