05-13-2017, 02:02 PM | #1 |
Advice on Generator vs Alternator
Since my generator is fried, I have to replace it. My car is going to be 12 Volts. And my 47 has been rewired with a remake of the original wiring harness. I've seen converted generator rebuilds on Ebay from $170 - $200 producing 40 amps. Powermaster sells an alternator that looks like a generator for $375 producing 90 amps. Then on the Ford Barn I read a thread and discovered EJ Whitney and had a great conversation with him. His alternator conversion using my existing generator cost around $450 producing 40 amps. That one is a little steep. I want an original look to my 47. I'm looking for input and advice. What would you suggest?
05-13-2017, 02:58 PM | #2 |
Re: Advice on Generator vs Alternator
More is not especially better unless you have a reason for more. Even if you have unlimited funds.
Don't go chasing higher amperage unless you have a definite need, such as a powerful amplifier or special lighting OR if you need to leave the headlights on for hours at a crime scene. Admittedly I'm also against converting to 12v. I would certainly investigate the reason for your generator getting fried soas it doesn't recur. |
05-13-2017, 03:41 PM | #3 |
I want to run LED headlights, taillights, interior bulbs.
05-13-2017, 03:48 PM | #4 |
Seems to me that LED's will draw less current than incandescent bulbs....
05-13-2017, 03:56 PM | #5 |
If you are going to run LEDs then 40 amps will be just fine.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
05-13-2017, 03:57 PM | #6 |
05-13-2017, 04:01 PM | #7 |
Then I'll go with a 12V / 40 amp generator, and get a 12V regulator from a Thunderbird or something. Thanks you all for the input.
05-13-2017, 04:05 PM | #8 |
That'll work!
05-13-2017, 05:20 PM | #9 |
I am in OZ, so our available old parts are different.
I got an EH holden 12 volt generator and removed the mounting ears and fabricated a lookalike sliding bracket using the original sidevalve strap.. At a glance and not so expert V8 people, it passes for original (look). Much nicer than an ugly modern alternator. |
05-13-2017, 05:44 PM | #10 |
Pooch - Sounds like a reasonable compromise! I am rebuilding a '39 3 ton Ford flat tray and looking at somewhere like $A800 for a 12v new 6V replacement in Oz or similar out of US with exchange & freight. Be interested in a photo.
Maybe there are cheaper rebuild alternatives to go from 6 - 12V Phil |
05-13-2017, 05:57 PM | #11 |
What part of your generator is "fried"? If its the coils you can replace them, I did. I am running the old 6 volt case and armature with 12 volt coils and a 12 regulator. I have had no issues, but its only been a year. Oh yeah, mine is the G series engine which has a generator all it's own.
05-13-2017, 07:05 PM | #12 |
Use a GM One Wire Alternator. Thet are around Fifty Bucks. Paint it black and dont open the hood.
05-13-2017, 07:24 PM | #13 |
LOL - Good one! I love it!
05-13-2017, 08:27 PM | #14 |
I respect your desire to stay "stock-looking" or even "stock-stock" .... But whatever form or appearance an alternator may take, functionally I like that they (1) are always charging, (2) have no brushes to wear-out or malfunction, (3) don't require an external regulator, (4) have less external wiring, and (5) they are inexpensive to repair. There's a old electric motor repair shop a mile fro m me which will test and repair an alternator within a few hours. The internal regulators are pretty much standard configurations and fit many housing.
My '47 came to me as a non-stock 12 volt and uses a 63 amp GM alt. With a good battery on-board .... Bright lights galore even at an idle. I'm good without LED's (which may need resistors to function). An aside .... Bubba has a friend who wires alternators to use an external regulator. No Chinese regulator parts please .... their longevity stinks. Last edited by Drbrown; 05-13-2017 at 08:36 PM. |
05-13-2017, 11:05 PM | #15 | |
05-13-2017, 11:06 PM | #16 |
05-14-2017, 12:57 AM | #17 | |
I will have to look, maybe one is Lucas and the other Bosch. Took a bit of hunting at swap meets to find a wide pulley as all holdens have narrow ones. Dunno what the pulley is off but it fits and I found 2, This second genny will go on my bus. As can be seen, my engine is open , so a modern alternator would just not do. Last edited by pooch; 05-14-2017 at 01:05 AM. |
05-14-2017, 06:49 AM | #18 |
They didn't use the case on the one they built for me just the ends and front mount.I believe they make a new larger diameter case from aluminum tubing.
"Never complain,never explain"... Henry Ford II |
05-14-2017, 07:49 AM | #19 |
The center is aluminum tubing, but think your confusing Whitney with Power Master on the diameter. The Whitney keeps the original dia.
05-14-2017, 08:07 AM | #20 |
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver Last edited by flatford8; 05-14-2017 at 08:09 AM. Reason: Delete |
