06-07-2014, 01:45 PM | #1 |
rear spring issue
Got my rear spring apart and started cleaning up the leafs. The ends of the first spring with the eyelets are gouged pretty bad from rubbing and I found this at the top near the bolt hole. Is this fatigue? Should I scrap it and order a new one?
06-07-2014, 08:20 PM | #2 |
Re: rear spring issue
It doesn't look like fatigue, but corrosion. If the eye ends are gouged, I would look at buying a new leaf. I had some main leafs made up by my local spring works, as most of the ones I had were either worn around the eyes, or saggy from a long life of use.
06-08-2014, 01:37 AM | #3 |
http://www.fordbarn.com/forum/search...archid=4031498
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
