Old 10-10-2019, 07:17 PM   #21
30aadoodlebug
30aadoodlebug's Avatar
Default Re: Pulling rear hub and axle shaft assembly on 50 woodie
I can usually figure this stuff out quickly. my restoration is stalled until i pull these shafts. Beat the crap out of them again after spraying more penetrating oil. nothing. I'm getting pissed.
30aadoodlebug is offline   Reply With Quote
Old 10-10-2019, 07:49 PM   #22
Greg58
Greg58's Avatar
I've had good luck hitting the axle with a 3lb hammer on the center, most of the time it will jump out. I've had to use a chain on two studs and a winch to put pressure on the axle and the strike the side of the axle with the hammer, the vibration seems to be what works.
Greg
Greg58 is offline   Reply With Quote
Old 10-10-2019, 11:17 PM   #23
rich b
rich b's Avatar
Originally Posted by JSeery View Post
Rich, then it's the bearing in the outer end of the axle that is tight?
Yes, probably rust has expanded and holding the bearing tight.
Another place where oxy/acetylene can be your friend.
