Old 02-25-2012, 11:46 AM   #21
John Stone
John Stone's Avatar
Default Re: This will ruin your day!!!!
Originally Posted by Tom Wesenberg View Post
How high are the pistons above the block?
How thich is the compressed haed gasket?
How deep is the head counterbore?
Just trying to determine the available clearance.
Counterbore is .052
Gasket is .075
Did not measure the top of the pistons above the deck but I know it wasn't any more than normal around .035 or so.
John Stone is offline   Reply With Quote
Old 02-25-2012, 01:14 PM   #22
James Rogers
James Rogers's Avatar
Originally Posted by John Stone View Post
I think you missed my post right before yours. The sleeve did not move.
Are all the sleeves 3/4"longer than the cylinder? If they are the builder didn't put them correctly. If it is only this cylinder, look closely at the top. Sometimes it is difficult to see a dropped sleeve. I say it is a dropped sleeve because you can see how the top was flexed at the sides where it broke and the top broke at a right angle to this pressure. Better look again.
Old 02-25-2012, 01:57 PM   #23
John Stone
John Stone's Avatar
I will just say that I can recognize a dropped sleeve. The sleeves are all too long. Why, I don't know. Never seen that before. Here are pictures. #2 had the broken piston. You will notice the cracks and those aren't all of them. I have rejected this block for rebuild. The owner said he had a couple of diamond blocks so will check them.
Old 02-25-2012, 03:59 PM   #24
James Rogers
OK, I'm convinced. What do you think was in the rebuilders head when he put those in? He either didn't know how to install sleeves or didn't have a facing tool for the boring bar. If the only problem is the sleeves, they can be pulled up and pinned to work correctly. If the white marks are cracks I would look for a better block too.
Old 02-25-2012, 04:11 PM   #25
hardtimes
hardtimes's Avatar
John,
Thanks for sharing as learning tool,eh
Curiosity: mabe the person who 'rebuilt' this engine didn't have the tools/equiment to step the bottom of the cylinder...isn't that process standard practice when installing sleeves?
With all those cracks (and more you say) was it an 'engine rebuilder' at all that did the work..to your knowledge? Just saying that I'm not a builder, but wouldn't start on a block with that cracked condition without repairs, etc...
hardtimes is offline   Reply With Quote
Old 02-25-2012, 04:11 PM   #26
John Stone
John Stone's Avatar
Yep, the white marks are cracks but the worst one is about 4" long in the valve chamber.
When I install sleeves I leave a step at the bottom of the cylinder. Can't come down. I have seen sleeves that were had a pin thru the lower part of the cylinder that would also work. Don't trust the press fit theory.
I had another thought that the rod might be bent but just checked and it has no bend or twist. I do know the owner was going fast when it let go.
Old 02-25-2012, 04:13 PM   #27
John Stone
John Stone's Avatar
Originally Posted by hardtimes View Post
John,
The original builder had a shop in Colorado but is long gone. You are right, I reject blocks that look like that.
Old 02-25-2012, 04:57 PM   #28
Tom Wesenberg
Tom Wesenberg's Avatar
"I do know the owner was going fast when it let go. "
That's why it's never good to play "catch up". That's when things go wrong and it also greatly increases the chance of an accident.
Old 02-25-2012, 06:06 PM   #29
James Rogers
That's the way I put sleeves in and if I find a customer has sleeves in like that I pin them with 1/4" bolts and loctite them in and grind them flush outside after boring the sleeve to size. This way the pin is almost invisible and keeps the sleeve in place.
Old 03-18-2018, 10:22 PM   #30
Tom Wesenberg
Nothing like reviving an old thread, but if John Stone is watching, what was the outcome of all this?
Old 03-19-2018, 11:27 AM   #31
John Stone
John Stone's Avatar
You really gave me a challenge. Six years is a long time considering a year ago I had a bout with Viral Meningitis and was in intensive care. The old brain doesn't remember quite like it did after that little episode.
Did a search of my records and found the pictures and the name of the guy I did it for but that was about it. I would imagine we replaced the block since that one was cracked. Haven't heard anything since so must have been successful.
Working on a B engine right now but still having some health problems so taking it slow.
Old 03-19-2018, 01:39 PM   #32
California Travieso
Send a message via Yahoo to California Travieso
Talking Re: This will ruin your day!!!!
Tom,
You must really be snowed in if you're reviving a six year old thread!
David Serrano
California Travieso is offline   Reply With Quote
Old 03-20-2018, 01:05 PM   #33
Jeff/Illinois
Jeff/Illinois's Avatar
https://www.flexglue.com/FLXGL/1.000...dtm?otsid=7952
How's about THIS stuff for a fix. Trust Phil!!
Jeff/Illinois is offline   Reply With Quote
