02-24-2012, 05:31 PM | #1 |
This will ruin your day!!!!
Took this out of an engine today. The owner said he was trying to catch up with the rest of the tour when it went bang. You can see the imprint of Winfield head. I'll bet bang is an understatement.
02-24-2012, 05:49 PM | #2 |
Re: This will ruin your day!!!!
Ouch! What caused that?
02-24-2012, 05:59 PM | #3 |
Just guessing, I'll bet he was able to drive it home?? Bill W.
02-24-2012, 06:11 PM | #4 |
yikes!!!
02-24-2012, 06:20 PM | #5 |
My guess at what happened is that the big end babbit came apart from lack of oil during the high speed revs, then the piston/rod assembly could move further up the bore, hit the head, knocking the crown off the piston. Just a guess.
02-24-2012, 07:59 PM | #6 |
www.whidbeymodelaclub.com |
02-24-2012, 08:00 PM | #7 |
Looks like a sleeve moved.
02-24-2012, 09:27 PM | #8 |
Oh yes, the old chicken and egg question!
So, what came first? Did the piston hit the head and leave the skirt, or did the piston top leave the skirt, then hit the head? |
02-24-2012, 09:44 PM | #9 |
The babbitt in the rod it OK. It looks like the piston top just separated. One thing I noted is the sleeve protruded out the bottom of the cylinder about 3/4". In this case the chicken layed the egg.
02-24-2012, 10:01 PM | #10 |
Didn't need to see that today.
It's 110 miles to Chicago We've got half a pack of cigarettes It's dark And we're wearing sunglasses Let's go. |
02-24-2012, 10:42 PM | #11 |
Ok....IMO the sleeve moved down, and the oil ring got hung up on the top edge of the liner. Bang !
02-24-2012, 11:57 PM | #12 |
Maybe I skimmed too fast but didn't see anything about a sleeve being found there. I'll bet there is no counterbore in the combustion chamber. He probably had "signs" before but didn't hear/feel them.
http://www.abarnyard.com/ |
02-25-2012, 01:38 AM | #13 |
I think its best if you can avoid installing sleeves or valve seat inserts.At least there is no chance of them coming loose if you dont install them.Any A or B can be safely bored to .125 OS.Even at that OS,you still have about 3/16" of water jacket thickness.
02-25-2012, 07:06 AM | #14 |
Told you the sleeve moved. Look at the top of the sleeve and it will be down the 3/4". This is why I leave a 1/8"ledge at the bottom so this can't happen. I have other ways to keep this from happening if the sleeve is bored all the way through but won't divulge those remedies here. If you have one you are unsure of, PM me and I'll explain.
02-25-2012, 07:12 AM | #15 | |
02-25-2012, 08:55 AM | #16 |
this happened to my truck! This is why it was Parked in '76
02-25-2012, 10:18 AM | #17 |
The sleeve did not move, they are just long sleeves. The head had a counter bore and there is no evidence of any other piston hitting.
I would think there might have been a casting flaw or a small crack in the piston along with hard driving. Have no idea how fast he was going when it went. |
02-25-2012, 10:26 AM | #18 |
Years ago a club member had the sleeve slide down enough that the ring caught on the top and locked the engine up. The sleeve was not pinned to the block in this case, how about in yours?
02-25-2012, 10:45 AM | #19 |
02-25-2012, 11:27 AM | #20 |
How high are the pistons above the block?
How thich is the compressed haed gasket? How deep is the head counterbore? Just trying to determine the available clearance. |
Thread Tools | |
Display Modes | |
