Old 10-17-2021, 11:21 AM   #1
sphooch
sphooch's Avatar
Default W.W. Tires
Hi guys , 2 quick questions: 1- i bought 2 w w tires mounted on nice black rims at Hershey. too bad they are the wrong color they are power coated black can i paint over the coating? [straw] and do the wheels have to be balanced? mine right now are not balanced. thanks THE HOOCH
sphooch is offline   Reply With Quote
Old 10-17-2021, 03:14 PM   #2
Incognito-A
Default Re: W.W. Tires
Hooch, generally speaking you cannot paint over powder coating. Finishes will not stick to it. You could try and rough up the surface and improve mechanical bonding but there may be incompatibilities chemically. At that point you have ruined the powder coat finish. Also powder coating is very difficult to remove.
IMHO keep the black look or sell them on and start from scratch.
Straight and true wheels do not need to be balanced at the speeds most Model A’s see and were not balanced from the factory in the modern sense. The “heavy” spot on the tire was mounted opposite the valve stem hardware at the factory.
Incognito-A is offline   Reply With Quote
Old 10-17-2021, 03:24 PM   #3
sphooch
sphooch's Avatar
Smile Re: W.W. Tires
great thanks for the info.
Old 10-17-2021, 04:02 PM   #4
chrs1961815
chrs1961815's Avatar
You can paint over powder coating if you rough it up and take some off with sandblasting. I have done it before in tight situations with epoxy over it. Not something I like to do though' especially on a wheel that can chip. Powder coated wheels just don't match the gloss of a good urethane paint.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-17-2021, 06:04 PM   #5
Synchro909
Synchro909's Avatar
I would never use powder coating. The wheels on my 1930 CCPU were powder coated when I bought it in a nice burgundy colour. They have faded to a dirty rusty brown colour and they look terrible. I bought the car out of the US so going back to the people who did it is out of the question. I think the job was done in Canada anyway.
I'm following this to see if I can avoid sand blasting al 5 and starting again. That would be expensive.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 10-18-2021, 12:10 AM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
They just fade. It’s not a flaw, it’s a fact. Here’s an example. The unmounted wheel has been hanging outside as yard art, and was done the same time as the mounted one.
File Type: jpg 748418F7-D067-4CFE-9897-5C50DF879CD7.jpg (76.4 KB, 25 views)
Old 10-18-2021, 04:54 AM   #7
Oldbluoval
Oldbluoval's Avatar
“I would never use powder coating.”
PERIOD….on anything automotive …..EVER
Oldbluoval is offline   Reply With Quote
