Old 10-01-2021, 07:30 PM   #1
chrs1961815
chrs1961815's Avatar
Default Rear spring and shackle bushing
I tried putting new bushings in my rear spring leaf and the ones I bought from Snyders a few years ago are too loose. They measure 0.75 outer diameter when the hole is really closer to 0.765. I have this same issue with the shackles I bought from them a few years ago too.
I am now wondering who sells a bushing that actually is the right size? Maybe Snyders has retooled their bushings and shackles?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-02-2021, 06:30 AM   #2
nkaminar
nkaminar's Avatar
Default Re: Rear spring and shackle bushing
It may be the hole rather than the bushing. You can order a bushing to any size from McMaster Carr but they are expensive. Or find a local machine shop to make one to fit. Or you could epoxy it in with JB Weld but that would not be recommended by most mechanics.
I am hoping you will get a better response by some of the other members.
Try calling Snyders. They are usually very helpful.
Old 10-02-2021, 07:13 AM   #3
chrs1961815
Yes I was thinking about calling Snyders. Something I forgot to mention was that the holes in the spring are perfectly okay - they aren't wallowed out or damaged in any way. Took a swing with McMaster Carr earlier but since this is such a special bushing I couldn't find anything.
Old 10-02-2021, 07:22 AM   #4
jimvette59
jimvette59's Avatar
I have used shim stock on some projects in the past. It can be purchased from Mc Master Carr or MSC on line. If they are out of round they should be reamed with a spiral reamer to the nearest size and a bushing should be purchased with the proper I D & O D. JMHO Jim T.
" If it was easy somebody else will be doing it "
jimvette59 is offline   Reply With Quote
Old 10-02-2021, 12:14 PM   #5
Patrick L.
Patrick L.'s Avatar
If you get them too tight they won't take grease.
Old 10-02-2021, 01:33 PM   #6
J Franklin
J Franklin's Avatar
Your spring might be aftermarket with a different size bushing.
Old 10-03-2021, 10:32 AM   #7
DJ S
DJ S's Avatar
Deleted.
DJ S is offline   Reply With Quote
Old 10-03-2021, 06:11 PM   #8
Jacksonlll
Jacksonlll's Avatar
A tiny piece of shim stock. You just want to keep it from rotating.
Old 10-04-2021, 04:45 AM   #9
Synchro909
Synchro909's Avatar
With only 0.005" difference in diameter, you are looking at 0.0025" clearance all round. That is well within the capacity of just about any of the Loctite (or similar) products. The bushes will slip in with finger pressure and when the Loctite sets, that's it
Old 10-04-2021, 04:53 AM   #10
chrs1961815
Thanks for the good ideas. I am going to call Brattons and see what size their bushings are. If all else fails, I'll either do the shim stock idea or loctite, or both.
Old 10-04-2021, 05:27 AM   #11
nkaminar
nkaminar's Avatar
If you use Loctite, use the one that is designed for setting bushings. I think that would be #638.
Old 10-04-2021, 05:56 AM   #12
Patrick L.
Patrick L.'s Avatar
Geez, maybe I'll catch up.
You're having problems with the bushings being sloppy in the spring eye !
If you have troubles getting the right size, you could try knurling them, or, prick punch them. [ 4 rows 90* apart]
Old 10-04-2021, 09:52 AM   #13
chrs1961815
I ordered the shim stock and that is what I will try with some loctite. Couldn't source any other bushings that were the right size so this is the direction.
Something else worth mentioning is that this is for sure an original spring. Somebody just took a 10 leaf and pulled one leaf out of it. Bushing holes are not worn, the new bushings are just a little undersized.
Old 10-04-2021, 10:18 AM   #14
Oldgearz
I just used Locktite bearing mount stick and the stuff really works well. Give it a try.
Oldgearz is offline   Reply With Quote
Old 10-04-2021, 08:25 PM   #15
Pete
Pete's Avatar
I never could figure out why people will spend hours figuring how to band aid Mickey Mouse fix something when it is so simple to fix right the first time.
As suggested before, since you have the measurements, find a machine shop that can make some 2 piece bushings from MOLY FILLED DELRIN. They should have a 1/16 thick flange on the outer ends.
THEY SHOULD BE A HAND PUSH FIT IN BOTH THE SPRING AND THE HANGER. SAME FOR THE PINS.
Use the shackle pins that are drilled for grease.
The nice thing about these is they never wear out if you keep them lubed.
Old 10-05-2021, 01:40 PM   #16
ThosD
ThosD's Avatar
I bought aftermarket replacement front shackles and perches recently for my early '31 coupe. The provided bushings for the new parts have a nominal OD of 3/4 (0.750) inches. My stock stock spring eyes and perches are made for bushings with a nominal OD of 11/16 (0.6875). Snyder's gets it right with their bushing tool. What's with the after market vendors? Do they just make parts for the '32 fords?
ThosD is offline   Reply With Quote
