04-08-2020, 06:41 PM | #1 |
Starting with a bad coil
Not much to do so I went looking on old Early Ford V/8 Forum
There was a long thread in 2015 about a V/12 Lincoln being hard to start. From all the info I would say it had a bad coil. What fooled them was after it sat 10 or 15 minutes it would start when they gave it a shot of starting fluid. It did not have the correct carb on it and most people blamed that. I think the real problem is what I see on here, a lot of BAD coils that get weaker the hotter they get. When the spark gets A LITTLE weak and won't start they will usually fire and run if starting fluid is used. The starting is more combustible and fires with a weaker spark. The lincoln V/12's have a big one piece coil that has two 36 Ford coils inside. G.M.
www.fordcollector.com |
04-08-2020, 07:20 PM | #2 |
Re: Starting with a bad coil
36 Ford coils inside." G.M. Get ready, George....Here they come...
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 04-09-2020 at 01:06 AM. |
