Old 10-23-2012, 09:19 AM   #1
Enbloc
Enbloc's Avatar
Default Edelbrock Heads On 221 Motor?
I've recently picked up some used, new Edelbrock heads. The engine in my '36 is a small bore 24 stud (81A).
Is it worth me bolting them on the small bore engine or does the drop in capacity/compression ratio make them worthless on the smaller engine?
I'm already running the stock 81A heads skimmed 60 thou.
Thanks
Enbloc is offline   Reply With Quote
Old 10-23-2012, 12:13 PM   #2
Brian
Brian's Avatar
Default Re: Edelbrock Heads On 221 Motor?
By all means run them; do the piston to head clearance check and machine them to acheive .050" squish.
Brian is offline   Reply With Quote
Old 10-23-2012, 06:26 PM   #3
Enbloc
Enbloc's Avatar
What sort of compression drop can I expect by using the Edelbrock heads on my 3 1/16 bore motor as the heads are designed for a 3 3/16 bore motor.
Old 10-23-2012, 06:31 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I don't think you'll find a drop, I think you'll have an increase. When you get your heads off see if you can compare the CC in both. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 10-23-2012, 08:09 PM   #5
Ol' Ron
Ol' Ron's Avatar
Walts right CCing is the only way to find these things out. guestamates just don't cut it.
Old 10-24-2012, 01:04 PM   #6
Enbloc
Enbloc's Avatar
Thanks for the info.
