Old 02-14-2024, 05:27 PM   #1
busmania
busmania's Avatar
Default What are these holes under dash for?
Driver side, under starter button. They look factory (and very much like the holes for the dimmer switch on the other side of the column). I might use one of the holes for something else but want to make sure they are not for something else first. Thanks!
8B54FDFE-BC5E-4916-8A2F-2627E0EC6838.jpg.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/
busmania is offline   Reply With Quote
Old 02-14-2024, 05:32 PM   #2
petehoovie
petehoovie's Avatar
Default Re: What are these holes under dash for?
Attachment 536441
Attachment 536442.
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 02-14-2024, 07:00 PM   #3
Kube
Kube's Avatar
Attachment 536441
Attachment 536442.
Drivers side looking like the dimmer switch holes was for the optional road lamps, aka fog lamps.
Kube is online now   Reply With Quote
Old 02-14-2024, 07:12 PM   #4
busmania
busmania's Avatar
Thanks Kube.
Old 02-14-2024, 08:02 PM   #5
Ggmac
Isn’t that where the super deluxe trip odometer was ?
Ggmac is offline   Reply With Quote
Old 02-14-2024, 08:13 PM   #6
Ken/Alabama
Ken/Alabama's Avatar
Not on a 40. Plus there was no such thing as a super deluxe in 40.
Ken/Alabama is offline   Reply With Quote
Old 02-15-2024, 05:39 AM   #7
Ggmac
Sorry, mixing 41 term . Where does the trip odometer set button go on a Deluxe 40 ? Sorry for the hijacking .
Old 02-15-2024, 06:31 AM   #8
aussie merc
aussie merc's Avatar
try dash dimmer and heater fan switch thats where mine are there should be same on otherside so right and left drive taken care of in one production piece
aussie merc is offline   Reply With Quote
Old 02-15-2024, 08:03 AM   #9
Ken/Alabama
On a 40 it’s on the back of the speedometer.
Old 02-15-2024, 08:27 AM   #10
Kube
Kube's Avatar
Nope. But I like the way you think.
Right vs. left hand drive instrument panels are distinct stampings.
Old 02-15-2024, 02:03 PM   #11
Ggmac
Thanks Ken .
Old 02-15-2024, 03:29 PM   #12
19Fordy
19Fordy's Avatar
Not sure this will help but, the dash on my 40 DeLuxe coupe looks like this.
All holes in the dash are OEM. I have not added any holes but did use a few of the stock holes for an ignition kill toggle switch and installing a 12V push button starter switch under the dash so as to bypass the OEM starter button. The stock starter button isn't connected. The last photo shows the instrument panel dash light dimmer switch almost behind the steering wheel lock.
Old 02-15-2024, 03:48 PM   #13
Kube
Kube's Avatar
Your heater switch should be to the right of the steering column.
Old 02-15-2024, 05:06 PM   #14
19Fordy
19Fordy's Avatar
Thanks, Mike, for that info. I checked your book and on page 5-17, there it is.
When I bought my 40 in 1963, the heater switch was on the left of the dash. I guess it was moved for some reason. Although, it makes sense that the heater switch would be on the right, closer to the heater.
1st photo shows where it's located now. Should it be located where the toggle switch for my fuel pump is now located in 2nd photo - to the right of the dash light dimmer switch.? There was already a hole there so I used it for my fuel pump on/off toggle switch.
Old 02-15-2024, 08:05 PM   #15
Kube
Kube's Avatar
It should be where that toggle is but seriously... it works fine where it is. I'd leave it there.
Old 02-15-2024, 09:45 PM   #16
19Fordy
19Fordy's Avatar
Thanks Kube for the reply. I will heed you advice as my car is not stock.
