Old 02-27-2024, 04:38 PM   #41
OldGold360
Default Re: 35/36 Pickup Seat Base
Originally Posted by Model51 View Post
None of the 1935-36 truck seat base plywood I've seen have the three hole re-enforcement plate on the seat base or the recessed area. Same for all of the Ford engineering parts drawings for this truck part.
I'm not sure why there are pickup seat bases with the grove cut but no plate installed.
The truck seat base blueprint you sent me illustrates the recessed pockets surrounding the adjustments holes. Did they not actually build them this way?
OldGold360 is offline   Reply With Quote
Old 02-27-2024, 09:08 PM   #42
Model51
Model51's Avatar
I honestly don't know if the 51-815360-A2 drawing represents a part Ford put into production or not. Unfortunately the dates in the upper top right hand corner are not clear enough to read and I also don't have any of the Engineering Parts Release cards to know what this part was used for or when. The drawing shows a hardwood multi-piece design which is different than the "normal" one which is made from plywood. It's possible this design is intended for the rare instance of a Panel Truck with an 18 gallon tank. There's no cab wall behind it so it needed a different design seat. This is all just speculation on my part but this drawing just doesn't fit into my knowledge base very well.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 02-28-2024, 08:05 AM   #43
Model51
Model51's Avatar
One final comment. Notice the part number ends in -A2. To me this indicates that there at least two versions of -A. I've only seen this nomenclature when there are two versions of the same part from two different vendors. It's likely that the -A1 version is plywood and the -A2 is assembled from hardwood pieces. Again this is more of my speculation since I don't have a copy of the -A1 drawing or any of the release cards which would likely definitively provide the answers.
At this point I'm not sure that anyone would which version was used especially since this part ends up not visible unless you take the seat out of the truck and flip it over.
Old 02-28-2024, 04:24 PM   #44
OldGold360
Thanks Dave.
