08-19-2017, 07:31 AM | #1 |
39 column lock warning
I'm working on an AV8 project and have been deciding which column and lock to use. The '39 cross steer is going to work for me so I started lining up the column with the original lock. The key wouldn't work so I had to take the cylinder out. After unlocking the column I put it in the truck and while working it back and forth, the steering locked up, even with the lock mechanism disengaged. After trying to research the complete assembly of the '39 lock with no luck, I removed it and took it apart.
What I found is that the locking plunger has a notch cut into it that allows it to be held in the slide mechanism by a small steel plate that is crimped in place. Apparently, this steel plate got worn away over the many years of engaging and disengaging of the lock plunger. It is not rusted, just worn away. The problem that I see with the '39 lock is that when this part fails, the plunger drops down due to gravity. If it happens out of the blue, particularly while driving, the results could be disastrous. The odds are probably slim but in any case, I changed to a '35 style lock with the plunger on the side. I'm only posting this to give folks a heads up since there seems to be very little information about this type of lock other than removing the lock cylinder. |
08-19-2017, 07:52 AM | #2 |
Re: 39 column lock warning
The piece that screws to the steering shaft, i take them off. No worry of if getting jammed up and in a hotrod what do you need it to lock for
08-19-2017, 08:26 AM | #3 |
You are correct with your warning. I have a '38 with the same style lock. I don't use the original ignition switch/lock and rarely operated it. Once while driving on the interstate I made a slight turn to exit and the wheel was locked. Over time, the weight of the lock plunger had turned the cylinder toward the Off position. That time I had plenty of time to turn the key back to the on position. I now check it regularly.
08-19-2017, 09:13 AM | #4 |
I am using w 39 truck column drop in my latest hotrod project and I had the exact same problem. So, after drilling out all and everything of the lock, I modified the column drop for my purposes ....
The key lock location is your starter button, the top switch is a two position switch for my 2-speed aftermarket heater/defroster unit which is hidden by a 46-48 heater box enclosure ..... |
08-19-2017, 10:44 AM | #5 |
The unexpected locking of the early Ford column locks is nothing new, it happened on a regular basis when the cars were very common.
The easy way to eliminate the problem is to remove the locking collar from the steering gear shaft. I was recently going through my various early Ford parts, came upon a half dozen steering column locking collars.. Hmmmm, don't remember removing that many of them. I do remember that it was a very common practice to remove the lock collars from the street rods. Some people liked to play games, reaching over and turning the ignition off, turning the key to lock and thereby creating a vehicle that was impossible to steer. Not a good thing when one is roaring down the road..
Bill.... 36 5 win cpe |
08-20-2017, 07:12 AM | #6 |
TomT, I like your improvisation. |
08-20-2017, 08:32 AM | #7 | |
Thread Tools | |
Display Modes | |
