02-22-2023, 10:33 AM | #21 |
Re: 39 rear brakes dilemma
You could check the E-Brake lever real quick, just disconnect the cable and leave it, push the lever in and try the drum and see IF it fits.
02-22-2023, 10:48 AM | #22 |
It looks like the parking brake is applied. Compare the picture of your brake with the picture of Rockfla's in post #13, the lever is much more forward on your brakes than on his. You can also see that the spring on the emergency brake cable is almost fully compressed on your brakes.
02-22-2023, 11:12 AM | #23 | |
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
02-22-2023, 12:27 PM | #24 |
The wire going from the center of the car out to the backing plates "should" have a "little" slack in it. IF Its banjo tight...BINGO!!!!
02-22-2023, 02:14 PM | #25 |
The vertical handbrake arm in its relaxed position should be back against the shoe ,Back of the hand brake cable at the gear box , Ted
02-22-2023, 04:45 PM | #26 |
I figured it was something simple or something stupid I had done. It helps to get other eyes on a problem.
02-23-2023, 04:18 AM | #27 |
The cable would have been adjusted to suit the wear on the old shoes. It is often the case that it needs readjusting (slackening off) after fitting new shoes.
Mart. |
02-23-2023, 08:54 AM | #28 |
Agreed, but I am surprised it was off as much as it was as the old shoes (shown in pic) were not that worn. In any event, an easy, if embarrassing, fix.
02-23-2023, 12:50 PM | #29 |
On a positive note, that means you kept your E brake properly adjusted !
02-23-2023, 03:04 PM | #30 |
Well, that is true! Hard to believe that they weren't too tight, but I have not driven the car much in the last few years. I am redoing the wheel cylinders, master cylinders and will replace the shoes if need be. I am finishing up the rears. The fronts are next, now that I have this "duh" problem figured out.
02-27-2023, 02:00 PM | #31 |
