02-20-2023, 07:14 PM | #1 |
39 rear brakes dilemma
I am rebuilding the brakes on my 39 Deluxe Fordor. I bought Raybestos replacement shoes and cannot get the brake drums back on. I thought it might be some differences in the shoes, so I put the originals back on and have the same problem, but not as severe.
There are four adjustment points on each wheel and I have adjusted them to what I think is the adjustment that is backed off the maximum adjustment, if that characterization makes sense. I have clearly done something wrong or don't understand the positioning of the shoes in order to get the drums back on. What is the secret formula or what have I done wrong? It all looks fine and conforms to the photos I have and the drawing in the shop manual. At the top of the shoes, the parking brake mechanism seems like it puts limitations on how much you can back off the adjustment. I watched a Youtube of someone installing brakes like mine. I struggled to get the cross arm for the parking brake on. He had no difficulty installing it, so maybe that is my issue. I don't see any other way to put it together. Any ideas?
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible Last edited by mhsprecher; 02-20-2023 at 07:20 PM. |
02-20-2023, 07:22 PM | #2 |
Re: 39 rear brakes dilemma
Have you backed off the parking brake adjustment—- perhaps disconnect it
Have the shoes been fitted to the size of the drum? |
02-20-2023, 08:33 PM | #3 |
Yes and yes.
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
02-20-2023, 08:54 PM | #4 |
The bottom adjustment helps center the shoe on the backing plate. When you hold the drum up to the shoes take a look and see what direction the shoes need to go, and adjust the bottom to make that happen. The top adjustment moves the shoes apart or in, you need to start with them fully in.
This is assuming stock 39 backing plates, not post-war or Lincoln or something else. |
02-20-2023, 09:01 PM | #5 | |
02-20-2023, 09:05 PM | #6 |
02-20-2023, 09:06 PM | #7 | |
02-20-2023, 09:11 PM | #8 |
Yes to all of the above. There is a drawing in the shop manual that is better. I can take a pic of mine and post it, plus the diagram from the shop manual.
02-20-2023, 09:13 PM | #9 |
38 Coupe: yes to your questions. I will take a pic of my brakes and post it. I probably can't get to it until Weds.
02-20-2023, 09:32 PM | #10 |
Here are pics of my brakes as I disassembled them. Hope they help
02-20-2023, 09:41 PM | #11 |
On the lower adjuster make sure the dots are facing one another. That’s the high point on the adjustment cam. Brings the shoes all the way in.
02-21-2023, 05:54 AM | #12 |
Is you wheel cyl seized, or possibly expanded a little during the install? The wheel cyl should collapse and give you the clearance. In one picture it looks like its stuck out a little .
Are your shoe tabs aligned with the piston slots ? Last edited by Ggmac; 02-21-2023 at 07:07 AM. |
02-21-2023, 09:08 AM | #13 |
"IF" it is any help to you, sometimes a picture is worth 1000 words. My 39 Mercury
02-21-2023, 09:19 AM | #14 |
This might help or not. I believe it was from a posting either here on the Barn or the HAMB.
Making the simple complicated for over 30 years. |
02-21-2023, 10:44 AM | #15 |
When installing the shoe return spring make sure it is installed in a way so it does not touch any of the linkage. If the ends of the spring are under any of the linkage it will bind the shoe operation.
02-21-2023, 04:57 PM | #16 |
I rebuilt the wheel cylinders as a part of this project.
I will check and make sure the dots on the adjusters are closest to one another. I think I did that, but will check again. I think the return springs are installed properly, but I will check again.
02-21-2023, 07:32 PM | #17 |
If you are still having problems, you could start by fitting just the shoes, like on a front brake setup. If they fit ok, then try with the emergency brake parts also fitted. If the shoes alone do not go on you can at least limit the investigation to the shoes.
If the shoes alone go on ok, and it's not ok with the emergency brake parts fitted then that will tell you where to look. I would leave the cables unattached for the initial investigation of the emergency brake parts. It's just a step by step sanity check approach. Mart. |
02-22-2023, 08:09 AM | #18 |
Thanks for all the suggestions.
I took a pic of my setup last night and looking at it and some of the comments, I am thinking that the parking brake cable is the culprit. I will move the parking brake lever out, which should bring the rear shoe in. I am hoping that is the problem. I have the parking brake fully released, but it may not be enough to get the drum on.
02-22-2023, 09:58 AM | #19 | |
02-22-2023, 10:24 AM | #20 |
"Maybe its me BUT the shoes at the top at the wheel cylinder seem a little too far out compared to my photo. ALSO did you compare your old shoes in this area to the new ones??? IF Memory serves me right, the new shoes have a slightly longer tang for the wheel cylinder cup than your old ones????"
I compared the new and the old shoes. They look pretty similar, but I will check again when I take the brake apart again. Your point about the shoes being farther out at the top is probably due to the parking brake. I will check that out today and see what that does.
