01-13-2018, 06:12 PM | #1 |
material in channel
Can anyone tell me what to use in the channel behind the front door on my '39 that the windlace staples to? Mine is gone. It looks like a fiber sort of thing in a friend's '39 coupe. Thanks in advance, Rod
01-14-2018, 09:26 AM | #2 |
Re: material in channel
you can purchase a replacement made out of plastic to go in the channel from restoration supply in pa.
01-14-2018, 09:32 AM | #3 |
Measure the channel width and depth. See which one will fit. https://www.bobdrake.com/tackingstrips There are ways to attach it (pop-rivets, metal tabs, sheet metal screws).
01-14-2018, 11:40 AM | #4 | |
Lebaron Bonney sells a plastic replacement. It is available in numerous dimensions. The plastic type holds staples very well.
01-14-2018, 02:27 PM | #5 |
