09-16-2023, 02:47 PM | #1 |
Hand brake cable/rod bracket?
Is there a ford OEM hand brake cable/rod support bracket to keep it from rubbing on where the rear radius rods bolt to the torque tube?
If it makes a difference I am using the early ford v8 garage’s brake hardware. |
09-16-2023, 03:27 PM | #2 |
Re: Hand brake cable/rod bracket?
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 09-16-2023 at 06:12 PM. |
09-16-2023, 03:31 PM | #3 |
09-16-2023, 04:13 PM | #4 |
Here's a few photos of that bracket on my 40 coupe.
Since you're using aftermarket brake hardware, you may have to custom fabricate your own bracket. Or, perhaps modify the Ford OEM bracket. Last edited by 19Fordy; 09-16-2023 at 04:26 PM. |
09-16-2023, 04:18 PM | #5 |
Thanks for the pics. May have to fab up something.
09-16-2023, 04:32 PM | #6 |
