01-09-2023, 11:51 PM | #41 | |
Re: running with no thermostats
How long did that engine last before showing blow-by and using oil? Cold running engines don't fully vaporize the fuel so oil is washed off the cylinders by raw gasoline, which wears the rings and cylinder walls faster. |
09-16-2023, 05:48 PM | #42 |
Just to prove how ignorant I really am, I'll ask, how do you install thermostats in a 1941 Ford?
Pull off the upper radiator hoses, set the thermostats in the heads with the 'umbrella' right side up and reinstall the hoses? Are there any other parts involved? My car doesn't have them but I want see what happens if I install them like Henry did. |
09-16-2023, 07:53 PM | #43 | |
Have heard that some cheap hoses will allow the stat to be pushed up the hose. In that happens you could add another hose clamp just above the stat to squeeze the hose slightly. |
09-16-2023, 08:40 PM | #44 |
In re-reading this old thread, the same old wives tales are here, so in an effort to clear up some alternative facts...
Water too fast: Simply stated, if X gallons per minute flow through the radiator, that same speed is how fast they flowed through the block. It's heat transfer will EQUAL that of water flowing XX gallons per minute. ½ the heat per gallon, but twice as many gallons = equal heat transfer, fast or slow. Will a thermostat maintain the temperature rating of the stat? Not gonna happen. A stat will simply open at it's temp rating, it has no control over temps beyond that rating. What it will do, is to close while coasting downhill on a cool day, in an effort to preserve engine operating temps. I can't picture a scenario where 160 stats would be better than 180 stats, except perhaps the parts department selling fake news.
Alan |
09-16-2023, 09:29 PM | #45 |
I had no end of problems getting the big inch flathead in my '41 coupe to run cool, both at idle in traffic and at 60+ on the highway. Tried everything, including removing thermostats, which as an engineer, I knew would be no help. Final solution was fixing the leaks, cleaning, and straightening the fins on the truck radiator that came with the car. Then I put the 170 thermostats back in to keep the engine running from running too cool, which is bad from both efficiency and longevity.
Took it out for a hard run two weeks ago when it was 95 degrees. Never got over 180 stuck in traffic or at 65 on the interstate. In summary, test your thermostats by putting them in a pan of warm water with a candy thermometer and heat the water up until you see them start to open at the rated temperature. If they check good, install them and forget about them, regardless of any overheat issues you are fighting. |
09-17-2023, 04:59 AM | #46 |
09-17-2023, 07:37 AM | #47 |
The idea that water moving too fast through the radiator causes overheating is just plain wrong.
Heat transfer increases with mass flow rate. Said in plain English, the more coolant you can flow the more heat you can get out of the motor. The origin of water moving too fast is from 1950s racers who were using stock used radiators with no pressure caps. A good flathead water pump at high rpm can pump more water than a marginal radiator can gravity flow. The pumps will force water out the overflow. If you are driving your car at 4000+ rpm with a marginal radiator then you may have too much flow. Everyone else should maximize flow. |
09-17-2023, 09:09 AM | #48 |
If you want an opinion, this is the place to be.
