Old 05-31-2018, 02:24 AM   #81
KULTULZ
KULTULZ's Avatar
Question Re: The forgotten 1960 Fords
Originally Posted by willowbilly3 View Post
I do somewhat understand Ford's numbering system. "Numbers matching" was once a term only used by the GM people, where it means something completely different.
On GM you could tell if major components were the one's a car left the factory with. On a Ford you can only tell if the part number and date code are consistent with ones built within a time frame the car would have been manufactured in. So a diligent restorer of a Ford can install a different part and still have it be consistent with the numbering system. On a GM, that's not possible. So even though the term has crept out of the GM camp and over to ours, it isn't the same thing. To the best of my understanding.
OK... Some BOW-TIE NUT is going to have to explain to me their version of numbers matching.
All manufacturers had to stamp VEHICLE VIN NOS (partial) on 68 up cars (engine-trans) as a means to thwart chop shops and that would give true meaning of NUMBERS CORRECT as I see it.
GM could not have stamped the VIN on every assembly part, other than an ID casting no. system similar to FOMOCO.
ATTACHED MAGAZINE ARTICLE- https://www.newsday.com/classifieds/...sals-1.6154213
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 05-31-2018, 09:31 AM   #82
KULTULZ
KULTULZ's Avatar
Post Re: The forgotten 1960 Fords
Originally Posted by Grumpy Rick View Post
A friend has a couple '60 Starliners, and he tells me they are the largest model Ford ever built.
Never checked that out.
The entire body of the new model was only slightly more than 36 inches high at the beltline, with an overall height of just 54.5 inches for the sleek new Galaxie Special Starliner models, and up to just 56.5 inches for the station wagons.
They were more than five inches wider than the 1959 models, with the brochures proudly announcing the tread width was now more than five feet!
The new Fords were actually wider than the legal limit in some states, although we know of no one receiving a citation for driving an “oversize
load.”
SOURCE- http://www.mre-books.com/sa25/sa25_4.html
Same issue as dualing headlamps in 1958.
The 60 STAR (and 352/360HP engine) was designed for NASCAR competition. FORD finally decided to no longer comply with the 1958 AMA ban on racing beginning with the 1960 model year. The 61 STAR returned to more earlier trim designs while basically the same car.
Old 05-31-2018, 06:17 PM   #83
mercman from oz
mercman from oz's Avatar
Default Re: The forgotten 1960 Fords
Regarding the Ford Starliners, did you realise that the Windscreens are totally different to every other Ford model of 1960? Usually, the Two Door Hardtops and Convertibles share the same Windscreen, but in case of the 1960 and 1961 Ford Starliners, that is not the case. The only other model that shares the same Windscreen is the 1960 Edsel Two Door Hardtop. I should mention that the equivalent model of the Canadian Meteor would also share this same unique windscreen. These are truly unique vehicles.
Old 06-29-2018, 10:01 PM   #84
mercman from oz
Ever wonder where all the 1960 Ford Starliners went? Unfortunately, here is a picture of a pair that never made it. The Ford Super Duty Transporter doesn't look too healthy either?
Old 06-29-2018, 10:33 PM   #85
scicala
scicala's Avatar
Sad picture.
Sal
scicala is offline   Reply With Quote
Old 06-30-2018, 02:19 AM   #86
KULTULZ
KULTULZ's Avatar
Exclamation Re: The forgotten 1960 Fords
This photo is from a TRUCK DRIVER INSTRUCTION MANUAL PG 27, the subject discussing low overhead clearances and road signs that warn of this ..
Old 06-30-2018, 07:25 AM   #87
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Wink Re: The forgotten 1960 Fords
I need the washboards and rear bumper off the blue one. What yard they at?
streetdreams is offline   Reply With Quote
Old 06-30-2018, 01:41 PM   #88
Herman Munster
Herman Munster's Avatar
You'd have to take the Way Back Machine to get those parts. That photo is very likely from 1960. The truck looks like a 58.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Herman Munster is offline   Reply With Quote
Old 06-30-2018, 07:31 PM   #89
streetdreams
Yeah, I know. Was just kidding.
Old 06-30-2018, 09:33 PM   #90
raceron1120
raceron1120's Avatar
Somebody from Washington posted these photos on the HAMB a few days ago:
raceron1120 is offline   Reply With Quote
Old 06-30-2018, 10:52 PM   #91
Herman Munster
Yeah, I know the guy.
Old 07-01-2018, 06:34 AM   #92
raceron1120
Was it you that posted 'em? I didn't notice the name. Looks like all of them could be saved. My first car was a '60 Ford but not a hardtop.
Old 07-01-2018, 07:22 AM   #93
big job
big job's Avatar
I wondered a long time if the Flxible Co. was buying Starliner emblems from Ford for
their line of Starliner buses? they sure look identical. see if I have a pic. This is a Starliner can't see emblem but its under the first window....sam
big job is offline   Reply With Quote
Old 07-01-2018, 10:29 AM   #94
Herman Munster
One and the same, AKA, "Bleach".
I don't know why I signed up as H. Munster here. I think I was probably watching repeats of the show when I signed up.
Old 07-01-2018, 10:29 AM   #95
rotorwrench
rotorwrench's Avatar
The 1960 Galaxie Starliner 2-door hardtop was a nice car since it was a fastback but the 1960 Mercury Park Lane 2-door hardtop is also a nice car. It had the bubble top front and rear glass and was truly one of a kind as well. They are pretty rare these days but they're still out there too.
Old 07-01-2018, 01:08 PM   #96
streetdreams
'60 Park Lane is awesome, especially with a 430. OK Herm, I'll ask. What's the plan for the Starliners?.
Old 07-01-2018, 03:38 PM   #97
Herman Munster
Well, I don't know. Those aren't my cars. If they were mine, the cars would be decent and I would be broke.
Old 07-01-2018, 05:16 PM   #98
streetdreams
I hear you. Just picked up a very restorable, complete '55 Merc Montclair to take up time and money I don't have. But it's a Rockdale Gray over Persimmon beauty I couldn't resist.
Old 07-01-2018, 05:26 PM   #99
scicala
scicala's Avatar
That's what my first car was when I was a kid. Mine had a greenish/teal roof and coves, with a white body. Be great to have one again.
Sal
Old 07-02-2018, 01:19 AM   #100
mercman from oz
Sweet 1960 Ford Starliner at the Annual Motor Muster at Greenfield Village Dearborn, June 16 this year.
